Author Topic: 70 RT, electrical system dead from one moment to the next  (Read 5760 times)
Offline 4 speed fish
Re: 70 RT, electrical system dead from one moment to the next
« Reply #15 on: July 20, 2012 - 07:40:33 PM »
Happened to me once,it was a blown fuse,sometimes it is hard to tell if the fuse is blown.
Offline Giveitawack
    • ebay
« Reply #16 on: July 21, 2012 - 03:03:03 AM »
Yes, I know it's rediculous...Are the fuses in the fusebox OK?
« Reply #17 on: July 22, 2012 - 08:49:38 AM »
more likely to be corrosion in the connectors causing intermittent power loss
Offline Padawan
  • Noob!
« Reply #18 on: July 22, 2012 - 10:59:17 PM »
I disconnected, cleaned, re-connected and wiggled about every connector from bulkhead connect to starter relay to battery to ground, fusible link still seems intact (at least my volt-meter made a sound), still nothing.  :horse:
1970 Challenger RT/SE 383
Add yourself here and then find others on the map
Offline Giveitawack
    • ebay
« Reply #19 on: July 23, 2012 - 01:08:17 AM »
Ignition switch?
Offline Padawan
  • Noob!
« Reply #20 on: July 23, 2012 - 09:47:18 AM »
Ignition switch?
I think I should at least have lights, outside and in the glove box, if it was the switch. It must be something very basic, but I think I've double checked it all.  :bricks1:
« Reply #21 on: July 23, 2012 - 10:28:12 AM »
light should work , they bypess the ign switch , you need to start tracing power , start relay out to the fusable link , into the bullkhead plug up to the ammeter etc
Offline Giveitawack
    • ebay
« Reply #22 on: July 23, 2012 - 10:51:23 AM »
Yes. Ampmeter bulkhead connections were burnt and corroded on mine
« Reply #23 on: July 23, 2012 - 01:27:05 PM »
How about taking apart the column connector with the larger gauge wires and see if you have 12vdc on the red wire? Gotta trace wires until you find where the power disappears. :2cents:
Offline Padawan
  • Noob!
« Reply #24 on: July 25, 2012 - 03:50:10 PM »
It was the fusible link!!! Nothing like starting her up after one week of silence :bananasmi
The Volt-meter still makes the noise when attaching the pins to both ends, that's why I thought it's still good, but bridging the fusible link with a cable remedies all electrical problems. Maybe it's also the connectors, the tip of the male part looks a little burnt, but seemed to connect just fine. Just ordered two replacement links from YearOne, I hope they also come with the male plug.
Thanks everyone for the tips, I learned a lot about the electrical system in my Challenger and thanks to this I can now also work on putting the 8-track back in.  :ylsuper:
Offline Giveitawack
    • ebay
« Reply #25 on: July 25, 2012 - 03:55:35 PM »
 :clapping:
Well done!
« Reply #26 on: July 25, 2012 - 04:12:42 PM »
Your local parts store would have had fuseable links in stock for probably 1/3 the price.  Glad you got it figured out.  Just make sure nothing is shorted and burning out the link.
Offline Padawan
  • Noob!
« Reply #27 on: July 25, 2012 - 08:46:54 PM »
The local Advance only carries 14 ga links, I think the one I need is 16. Yeah, I hope there is no shorting burning out the link, but at least I'll know what it is if she goes silent again. ;D
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #28 on: July 28, 2012 - 02:37:47 PM »
 :bananasmi  Nice job!  :thumbsup:  Glad you got it figured out!
