Rear Disc Brake Kit, who makes the best one?
Author Topic: Rear Disc Brake Kit, who makes the best one?  (Read 6085 times)
Offline 73restomod
« on: July 19, 2012 - 12:07:01 AM »
I want to upgade to rear disc this fall/winter on my Challenger. I don't want to run the "green" bearings either, car has a factory Spicer sure-grip. I recently had my machinist make new spacers for it out of Tool Steel. Not looking for wild or exotic and It has to have a parking brake. Any suggestions?
Re: Rear Disc Brake Kit, who makes the best one?
« Reply #1 on: July 19, 2012 - 08:34:39 AM »
I just installed DrDiff rear disc's on my new Dana?
« Last Edit: July 19, 2012 - 08:56:40 AM by brads70 »
Offline GreenFish
« Reply #2 on: July 19, 2012 - 12:12:26 PM »
What does Dr.Diff Charge for just a disc brake kit?
« Reply #3 on: July 19, 2012 - 12:27:44 PM »
I think it's just under $500. I went with the upgraded aluminum caliper mounts and e-cables. Both were $100 each extra I think it was?  Cass discounted me 40 bucks because I got my own rotors elseware to match the front rotors.
Offline 73restomod
« Reply #4 on: July 19, 2012 - 01:22:20 PM »
Very nice
Sent from my DROID RAZR using Tapatalk 2
Offline jimynick
« Reply #5 on: July 19, 2012 - 11:24:25 PM »
Brad, are these the Explorer brake?
« Reply #6 on: July 22, 2012 - 05:14:02 PM »
The rotors are 89 Toyota Cressidia, the calipers I think are Cobra" ? What year etc... I don't know I'll have to ask him?
Offline Danishmopar
  • 70´ Challenger. Denmark, scandinavien.
    • Overhauling 70´Challenger
« Reply #7 on: July 28, 2012 - 01:16:32 AM »
Cool rotors  :2thumbs: do they have the same messurements as them Dr, diff sells.
Work and Supportet your forces at 821st Air Base Group. Thule AB, Greenland
Pictures of My challenger: http://picasaweb.google.dk/dennisogkatja/Overhauling70Challenger#
« Reply #8 on: July 28, 2012 - 07:38:27 AM »
Yes exactly the same , Cass told me his kit uses 89 Toyota rotors!  :2thumbs:
Offline TROUBLE987
« Reply #9 on: August 01, 2012 - 09:30:16 PM »
Brad where did you get the Dana from..did you order it or do it yourself..?
« Reply #10 on: August 01, 2012 - 09:38:21 PM »
I ordered it from DrDiff ( Cass)  brand new Strange 60 , tru trac ,oversize tapered roller axel bearings, HD 3/8 retainers, 3:55 gears, rear disc brake kit with upgraded aluminum caliper brackets. 1350 u-joints
Offline Kevin71
« Reply #11 on: August 04, 2012 - 11:37:59 AM »
I put the same rear disc and rear end on my challenger.  Put new master cyclinder with larger bore.  I couldn't get the brakes to lock up no matter how hard I stomped on them.  Ending up adding power to them.  Got SSBC front disc.  No one I tallked to had any ideas other than it wasn't moving enough fluid.  I was wandering if you had a similar problem?
Offline Kevin71
« Reply #12 on: August 04, 2012 - 11:53:41 AM »
Hey do you have a rear sway bar.  I put a original style TA on mine and the brackets interffered with the calipers.  I had to weld up the hole and move the mount to the inside a little to make sure they cleared everything.
« Reply #13 on: August 04, 2012 - 01:18:53 PM »
I haven't finished yet so I've never driven it. I have another M/C from Cass ( 1 1/8") that I plan on converting to hydroboost. I have one from a Asrto van.
I have a Hotchkis rear sway bar and it fit with no problems.
Offline Kevin71
« Reply #14 on: August 04, 2012 - 04:07:42 PM »
Yea the way the hotkiss mounts I imagine it was no problem.  Mine stops fine now, but I wasn't anticipating havng to upgrade further.  Every time I upgrade one thing I have change something else.  These things are worse than a boat.
