Question About Shop Lights
Author Topic: Question About Shop Lights  (Read 1369 times)
Offline daveh
« on: July 19, 2012 - 11:01:21 AM »
Hey guys, I'm not sure where to ask this so if this isn't correct sorry in advance.  I’ve recently moved and I am setting up the new garage.  In my old garage the previous owner had 9, 8’ florescent shop lights wired to one switch.  I never gave it a thought since they always worked great in the cold and hot.  He probably had other receptacles on it also.  I don’t know.
Now that I’m setting up my shop I was going to do the same thing.
My question is can I install 9, 8' florescent lights (double bulbs) on a single 15amp breaker?  I know these lights take very little power but I just wanted to be sure.  Thanks
Offline 72cudamaan
Re: Question About Shop Lights
« Reply #1 on: July 19, 2012 - 12:28:30 PM »
Volts X amps = watts. the fixtures will show wattage use. add up your total watts
and compare. You should only use roughly 80% of your available wattage. 110 volts
times 15 amps = 1650 watts. 80% = 1320 usable watts.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline daveh
Offline daveh
« Reply #3 on: July 19, 2012 - 01:22:27 PM »
So it's looks like I should use a 20amp breaker?
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #4 on: July 19, 2012 - 01:41:33 PM »
Quote
And 12 gauge wire.
The Brewmaster
Offline 72cudamaan
« Reply #5 on: July 19, 2012 - 05:15:24 PM »
According to my calculations, you could use 9 shop lights with 2  75 watt bulbs each.
9 x 150 =1350. You would be slightly above the 80%, but not enough to use a 20 amp breaker.
Just make sure it is dedicated to only the lights. Or if you are wiring other things, put 1/2 the lights
on a circuit with a coupla outlets. And the same with the other 1/2. That way if you pop a
breaker, you still have some lighting to see your way to the panel.
Offline 72cudamaan
« Reply #6 on: July 19, 2012 - 05:16:51 PM »
Also for what it is worth, nominal voltage varies by location. You may have 110 up to 120 volts.
That will also change your total wattage. Easy to measure.
