well I got to the wiper switch. Everything seemed fine. I took the connector off and cleaned both it and the switch. Still nothing. I put a new motor on a while back and the wipers would work half the time. When they would work, they were sluggish to start, and then would get going. Then, they just quit all together. I can run a wire from the positive end of the battery to one of the motor wires and will work a little bit, so I figure its is the switch? Is there any diagrams on this...maybe I'm not grounding good at the switch?
