Author Topic: Installing Mufflers in the stock location.  (Read 767 times)
Offline 1970A66D21
  • Livin in Vegas
« on: July 19, 2012 - 09:26:59 PM »
I would like to install mufflers in the stock location,beside the fuel tank.I have  long tube headers, X-pipe and exhaust tips for my 340..Pipes will be 2.5".Will not be running resonators.Hope to use Flowmaster 40,s with needed outlet location.
 Is there a disadvantage to installing the mufflers so far back:as in performance or sound?
Offline NCtrueconservative
Re: Installing Mufflers in the stock location.
« Reply #1 on: July 19, 2012 - 11:17:32 PM »
I have my mufflers installed in the back where the resonators should be.  I'd say the difference in performance would be inconsequential but I could be wrong.  As far as sound, it sounds sick!!!  :burnout:
1973 Dodge Challenger Rallye (pictured), 340, Slap Stick
1998 Dodge Ram, 5.2, Black, tinted windows, dual exhaust, blackout headlights, tailights
« Reply #2 on: July 20, 2012 - 08:57:11 AM »
You'll want to run a muffler that's the same shape as the stock muffler.  The flowmaster 40 looks like a resonator...not an E-body muffler.  It won't look right back there.  Magnaflow and some other brands make a round muffler that will work back there.
The sound will be different if the muffler is in the back vs infront of the axle.  It should be a little quieter and you won't get as much of a raspy sound at the back.  The only disadvantage to the muffler being at the back is that it won't get as hot and could collect more water.  If you run a stainless muffler, you don't have to worry about that.  I would recommend drilling a small weep hole in the back of the muffler.(down low)  That will let some of the condenced water drain out and lengthen the life of the muffler.
