Author Topic: 727 upshift question  (Read 1306 times)
Offline Jamie
« on: July 22, 2012 - 03:00:36 PM »
ok guys, 70 cuda 360 w/ freshly built 727. 2400 stall. my question is that when getting on the throttle a bit I shift manually from 1st to 2nd it has a delay , not a slip . If i leave it in drive it shifts perfect ( firm but not tire chirping) which is what I asked of the trans shop. I have the factory shifter on the floor. Any thoughts?
I will finish a project.I will finish a project. I will finish a project.
70 barracuda plum crazy
( current goal is to keep just one car) AND FINISH IT!
08 charger r/t  w/road & track package
2011 silverado
Re: 727 upshift question
« Reply #1 on: July 22, 2012 - 04:33:45 PM »
Does your tranny have a shift kit?
Offline Jamie
« Reply #2 on: July 22, 2012 - 08:14:30 PM »
No shift kit, but they said they upgraded the clutch pack to a 5 from a 4 or something like that. I told them I did not want a snappy trans that get old after a while. I am baffled as to why it feels crappy only during manual shifts
2011 silverado
Offline tactransman
« Reply #3 on: July 23, 2012 - 06:44:13 AM »
It sounds like 1-2 shift bind up from the rear servo not being shimmed solid. Look at reply #5 on this thread  http://www.cuda-challenger.com/cc/index.php?topic=20391.0
Terry-tactransman
Union, Mo.
Offline Jamie
« Reply #4 on: September 14, 2012 - 08:23:56 PM »
O.K. , awesome thread on 727 know-how Terry! I am back to the trans shop that bench built mine. Along with the crappy manual upshift(which I pointed out the solid servo tip) I am now getting a 2-3 shift flair under acceleration. They think it is my lokar kick down cable not having enough throw for the trans lever. So I picked the car back up, put it back on my lift and me and my mechanic agree that the carb end of the cable moves the same as the trans end. full throttle=full lever throw.??????  Also I seem to get a weird neutral out if i am at light steady throttle in 3rd ( steady cruising at 50 mph ) As soon as I apply small amount of throttle it lumps back in gear and pulls fine as long as car is accelerating. I feel something is fubar inside trans.
2011 silverado
Offline barracuda7199
  • needs a resto but having to much fun right now
« Reply #5 on: September 15, 2012 - 02:00:03 PM »
sounds like to much clearance in the forward clutch drum. the only way to verify that (that i know of) is to take the trans apart and break the feeler gauge out.
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Offline tactransman
« Reply #6 on: September 15, 2012 - 02:40:00 PM »
Your 2-3 flair is more than likely the cable set up not right yet. If it isn't the cable, then the 3rd gear clutch pack is probably burnt from the cable not being set right in the beginning. Set the cable alot tighter and see if the flair is gone.
Terry-tactransman
Union, Mo.
