Author Topic: engine tuner in denver co  (Read 1370 times)
Offline EMCD
« on: July 22, 2012 - 03:48:01 PM »
I have a 408 stroker, 770 holley carb, dougs headers, rhs heads, dl plain intake, crane ign box. The car doesn't run well at all and I cannot get it tuned right. It bogs down and almost stalls when I punch it and is unreliable. Looking for it to run great. No need for a fancy dyno tune. This motor has set me back some $, so I'm light on cash. Any ideas for a good inexpensive shop?
Offline dodge freak 2
Re: engine tuner in denver co
« Reply #1 on: July 22, 2012 - 03:55:18 PM »
Yeah, your own garage.
We could help you tune it.
First get the timing set correctly, all in about 34 degrees--you can adjust for best power later on.
Then move on to the carb, what jets and power valve is in there right now
Offline EMCD
« Reply #2 on: July 22, 2012 - 04:12:49 PM »
The motor was built by ridge reamer and the carb was also rebuilt there to match the engine. I added a tranny cooler, larger almn pan  and a oil filter reloc and still my avg temps are 210*. I'm up for anything, I just want to start enjoying the car.
« Reply #3 on: July 22, 2012 - 10:18:54 PM »
Or I could fly in .
 are you using a clutch fan ?sounds like an air flow problem , is it getting hot in traffic idling or running on the highway ? what cam , how many inches of vacuum at idle in gear ?
Offline EMCD
« Reply #4 on: July 23, 2012 - 04:30:36 PM »
34* of initial timing?
Offline 72cudamaan
« Reply #5 on: July 23, 2012 - 04:54:59 PM »
No, that would be 34*  total timing at about 3000 rpm. And what vacuum reading
do you have at idle?
If I cant fix it, it's broke
Andy  (phukker whither)
Offline EMCD
« Reply #6 on: July 24, 2012 - 12:44:28 PM »
ok. my buddy is helping me out with the timing. what should the initial timing be, 8-12*? also, what is a good vacuum reading at idle? it gets hot in traffic, i have a dual elect fan with shroud. i thought with the oil filter reloc kit adding 2 qt of capacity and getting the filter away from the header along with the tranny cooler and larger pan adding 7 qt's that my temps would drop at least 10*. so far, no drop at all. something is definitely wrong..
« Reply #7 on: July 24, 2012 - 11:04:34 PM »
I would disconnect the vacuum advance & leave it off set the initial timing at 16 & total timing at 36* total .
 Manifold vacuum could be anywhere depending on the cam but the carb needs to be tuned to work with the vacuum at idle in gear .
Offline EMCD
« Reply #8 on: July 26, 2012 - 10:32:33 PM »
So, when we timed to the above settings, it ran great until it warmed up. Then it started to perform poorly. We checked the temps of the fuel and it was over 170. I have a 165* thermostat. I'm thinking of changing that out for a 180 and getting some heat socks for the braided line that must be getting heat soaked. Any other ideas?
« Reply #9 on: July 27, 2012 - 08:04:04 AM »
is the heat crossover blocked in the intake ? A carb spacer / isolater to reduce heat the carb helps as well .
This is some interesting data http://www.dodgecharger.com/forum/index.php/topic,52284.0.html
Offline EMCD
« Reply #10 on: July 27, 2012 - 09:59:39 PM »
It's an eddy 2xplain intake with a wooden carb spacer. So, I'm at a loss. The headers I have are doug's ceramic coated, so the heat should be in check, right?
« Reply #11 on: July 27, 2012 - 10:48:50 PM »
ok so back to timing & tuning , lean will cause heat
