Author Topic: Low Fuel Warning light blinks on and off  (Read 1399 times)
Offline spamtank
« on: July 22, 2012 - 05:43:11 PM »
Since I've owned the car, the LFI light has been on constantly.  However, I remember seeing a loose dark blue wire hanging in the dash when I replaced the radio recently.  I went back and did some reading and sure enough, that should have replaced the black regulator wire.
After fixing that, my gauge still seems to work with new "feature".  The low fuel light blinks on and off, and the fuel gauge pulses up and down about 1/16 of a tank from where it should read.
I thought perhaps the LED light that I installed in the console might have disrupted the desired circuit resistance/current draw.  So I replaced that bulb with a fresh 1892.  But this resulted in little to no change.
 I'm going to check and make sure I have good ground connection at the LFI relay.  I haven't messed with the sending unit.  It's a replacement unit that I reinstalled after replacing the tank.  As the gauge was working, except it seemed to be off by 1/8 -1/4 tank.
Any other thoughts?  :clueless: :dunno:
Thanks
Rick
« Last Edit: July 22, 2012 - 08:24:43 PM by spamtank »
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Offline spamtank
Re: Low Fuel Warning light blinks on and off
« Reply #1 on: July 26, 2012 - 10:06:22 PM »
Moved from another thread ...
While I'm not familiar with the SE's low fuel light relay and how it is wired into the cct, if you only have one wire connected to the threaded stud on the sending unit, you must be missing the ground wire connection. That one wire on the sending unit still needs an electrical path back to the -ve of the battery. If there is no ground connection, you are open circuited. I remember reading a thread where you said your low fuel light blinked from time to time. Does the gauge work at all?
Thanks for your help guys.  I don't want to hi-jack this thread with my problem.  That said, my gauge works, but it was off by about 1/8 - 1/4 tank.  The light was on constantly.  From the service manual, I discovered that the black wire from the regulator should have been replaced with the blue wire from the low fuel relay.  Once I fixed that, the low fuel light blinked on and off with about a 10-20% duty cycle about every 30 seconds while sitting still.  And while driving over bumps it exhibited what I would describe as an intermittent.  I discovered the LFE light and fuel gauge work in the accessory position of the ignition switch.  So I'm gonna have my wife watch the light while I try to move some "groundy" things around back by the tank.  This might turn something up.  Since the low fuel relay contains thermally actuated bi-metalic switches, I think the time it takes to register a change if fairly slow, but maybe the grounding of the relay itself has some affect.
There are a lot of electrical connections that are returned through the chassis, and don't have separate ground wires.  The dome lite, oil pressure sending unit, horn, etc.  I think the fuel gauge is one of them.  But I'll double check this weekend.
I'll copy this over to my thread so I don't drag this off on a tangent from the OP.
2013 RT Plus 6M
« Reply #2 on: July 26, 2012 - 10:32:38 PM »
The fuel gauge ground does go through the body, BUT, because the sending unit is isolated from the tank by rubber gaskets, it needs a ground wire to 'bridge' that isolation. If you have no ground wire at your sending unit strapped to the fuel line and then screwed to the shock support crossmember (at least that where it goes on my 73), take a small hose clamp and attach one and see how it works.
