Author Topic: Blew muffler all to H,,ll  (Read 1002 times)
Offline 300
  • 69 chevelle,67chevelle , 70 barracuda
« on: July 22, 2012 - 09:11:03 PM »
Well, got new build done(70 Cuda 340 sixpack). Everything is new. Had the engine builders here and after the start up shut it down to make some adjustments. Went to start again no go no spark. Again and again same thing (Has MSD Digital box) Anyway after about 6 try's Boommmmmmm. Blew the back of one of the mufflers right out and what was a AAR one is now a round nothing( can,t hear out of left ear good as the pipe exists in front of rear tire, On the phone to MSD they said bad box it was only giving intermediate spark causing to much fuel in bowl and exhaust ( YA) also said to disconnect ballast resistor although my friend that works on Mopars and does MSD wiring had it hooked up, (He wasn't,t here for fire up). Now have to order new AAR mufflers and wait for new MSD box, and try this another day. Wow what a fun day
Re: Blew muffler all to H,,ll
« Reply #1 on: July 22, 2012 - 09:19:05 PM »
Bummer! I want to hear/see that thing of beauty on the road!  :pullinghair:
« Reply #2 on: July 23, 2012 - 01:30:23 PM »
If the MSD was wired with the ballast resistor in cct, it won't work properly. MSD box needs 12vdc, the ballast resisitor drops the voltage to like 9vdc.  Take  the resistor out of the cct before you fire up with the new box. :2cents:
« Reply #3 on: July 23, 2012 - 04:54:04 PM »
the ballast will have a blue & brown wire , the red trigger wire for the MSD Must be connected to both the blue [12v run ]& brown [ 12v start ] wires to work .
Offline 300
« Reply #4 on: July 23, 2012 - 08:02:54 PM »
Thanks I,ll give that a try. We did hook up the wires as you said,but I guess the box was junk by then
