Author Topic: 2 speed to 3 speed conversion  (Read 2980 times)
Offline VTMopar
« on: July 22, 2012 - 10:26:03 PM »
Would like to convert my 2 spped wiper motor to a 3 speed on my '70 challenger.    I have the 3 speed motor & pivot arm and the "arms" or 3 speed wiper transmission.....  I also have the 3 speed wiper switch.    So -- what am I missing for this project?
Any tricks before I start
One thing -- my 2 speed has a "ballast resister" (2 prong) attached to it ( in addition to the one on the firewall.()   What's this all about?
Thanks for your help!
VT Mopar
VT MOPAR
Re: 2 speed to 3 speed conversion
« Reply #1 on: July 23, 2012 - 05:31:12 PM »
I think you have all you need except the molded plug as the wires are in different positions on the back of the switch . Slotts may be able to help with the plug .
Offline hotrod98
    • Maniac Musclecars
« Reply #2 on: July 23, 2012 - 06:01:19 PM »
Seems like I had to cut the two prong part loose from the two speed plug plug to seperate it to fit the three speed wiper switch. It's been a while. I know it's different under the hood as well. Been too long.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline VTMopar
« Reply #3 on: July 24, 2012 - 06:28:34 PM »
Anyone gone through this process who might be able to provide more specifics?
Thanks
VT Mopar
VT MOPAR
Offline JayBee
« Reply #4 on: July 25, 2012 - 08:51:08 AM »
I did this 2 or 3 years ago, my car is a 1970 also. The most important thing I found was getting the correct parts.
Wiper motor - 3431077
Motor crank - 2822289
Link(from crank) - 2822293
Var. spd swc - 2770380
The rest was just bolt on and plug in. I didn't change anything in the connector to the new switch as far as I recall.  The ballast resistor is only for 2 speed applications.
Sorry, just dawned on me that you're converting to a 3 speed. Since the switches are a different size it looks like there will be the need for some connector modification.
« Last Edit: July 25, 2012 - 10:12:26 AM by JayBee »
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline VTMopar
« Reply #5 on: July 25, 2012 - 09:40:35 PM »
Hmmm     Is the only difference between a 3 speed motor and variable the switch?
VTMopar
VT MOPAR
