Author Topic: calipers  (Read 1230 times)
calipers
« on: July 23, 2012 - 10:04:14 PM »
One of my stock calipers is siezed. Both are the original 73 calipers. I'm planning on buying two replacements. Does Wilwood or whatever make a caliper that is better than stock and not too difficult to fit?  :dunno:
Re: calipers
« Reply #1 on: July 23, 2012 - 10:32:37 PM »
To my knowledge most aftermarket kits use the Drum brake spindle not the disc one to attach adapters too . Check out Scarebird
Offline GreenFish
Re: calipers
« Reply #2 on: July 24, 2012 - 08:24:22 AM »
I converted my front disc brake Cuda (70) to wilwood 4 piston disc breaks. It was one of the easiest jobs ive ever done.
Offline MoparDealer1971
  • CDRJ Dealer
Re: calipers
« Reply #3 on: July 24, 2012 - 03:16:26 PM »
Doesn't Mancini have an adapter kit for this?
1971 Dodge Challenger - 2010 Plum Crazy Pearl, 318 4-bbl, 904, 2.5in Pypes Performance X-pipe exhaust, Hemi torsion bars, 2in rear drop springs, Hellwig Motorsports sway bars, 11.75in Drilled/Slotted front brakes
Re: calipers
« Reply #4 on: July 24, 2012 - 11:59:36 PM »
Check out Scarebird
I'll check. Thanks guys
Just calipers and caliper brackets? or everything?
Offline GreenFish
Re: calipers
« Reply #5 on: July 25, 2012 - 08:46:43 AM »
No I did everything up front.  I had disc breaks and put on the willwood kit. I think I kept the stock spindle but I can't remember now.
Kit was calipers, brackets, and rotors, hardware. I added braided steel lines and upgraded my master cylinder as well just for good measure.
