What thought have you given as to where you would want to go with the car? IE: restore it to original stock condition or change out the drivetrain to a 340 or big block with a manual transmission? Once you answer that question, start putting some numbers together as to costs for parts & labor. Either way you go, if you are not doing the majority of the labor, you will likely spend more than what you would buying a completed car as noted above. We just want you to make the best decision and certainly avoid the "now what do I do" question.
