Author Topic: engine type  (Read 1660 times)
Offline cacaofugl
engine type
« on: July 24, 2012 - 02:57:35 PM »
can any of you tell me excatly what engine model this is the guy i bought it from a year ago told me it was a srt 8 hemi but is it a 5,7 or 6,1 or somthing els, so maby one of you can tell me just by looking at the picture or is there a vin code on it somewhere
Offline Justins72
Re: engine type
« Reply #1 on: July 24, 2012 - 05:03:08 PM »
Im sure someone with more knowledge will answer for sure about how to check but i know if its a real srt8 motor then its 6.1
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Re: engine type
« Reply #2 on: July 24, 2012 - 05:26:14 PM »
They put 6.1's in the SRT-8's until recently. So that is a good bet. The 5.7's were in R/T's.
Offline hpe600rt
  • how sweet it is
Re: engine type
« Reply #3 on: July 25, 2012 - 06:36:26 AM »
srt is a 6.1 but it may be a 5.7 as they look the same from the heads down
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
engine type
« Reply #4 on: July 25, 2012 - 07:01:36 AM »
It has the LX platform accessories. (charger, magnum, challenger) so it most likely isn't a truck version of the 5.7. The 6.1 and earlier 5.7 have different intake ports (04-09 model years) in late 2009 they tweaked the 5.7 for more power and people commonly refer to it as the " eagle" version. Is there a cast number on the xv intake? I would start there as it should tell you if you have 5.7 ports or 6.1 ports. And then you should know that the rest is.... Unless they swapped eagle heads onto it, but I doubt it.
Good luck!
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
Offline cacaofugl
Re: engine type
« Reply #5 on: July 27, 2012 - 01:35:10 PM »
i cant seem to find a cast number on the xv intake, do you think it would be on the bottem side so i have to take it off to see ?
Offline diyhemi.com
    • DIYHEMI.COM
engine type
« Reply #6 on: July 27, 2012 - 03:56:24 PM »
Measure the intake ports on the heads and then compare them to known factory dimensions (google, I don't remember them)
Offline Modern Muscle
    • Modern Muscle Performance Group
Re: engine type
« Reply #7 on: July 31, 2012 - 02:53:48 PM »
easiest way to tell is the 5.7 blocks are black 6.1 Blocks are orange
Offline AARuFAST
  • AARuFAST
Re: engine type
« Reply #8 on: July 31, 2012 - 08:07:33 PM »
Ask the previous owner if he has any receipts on the engine......... He should be willing to show you some paper work on the engine.............
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline ORNOT2B
Re: engine type
« Reply #9 on: October 11, 2012 - 03:56:55 PM »
If the Block is painted Orange it is a 6.1 and if it is unpainted it is a 5.7
MOPAR OR NOCAR!!
