the power is fed from the voltage reg , , it is a pulsing voltage averaging around 5 v , the power feeds out to each guage with the black wire , then passes through the guages & is sent out to the sending units grounding at the senders , the varying resistance through the sender controls the reading on the guage . To clarify there is no gauge ground on the dash , they are isolated from ground .
