Author Topic: Ye old Grille Question...  (Read 1258 times)
Offline HP_Cuda
  • Mopar or No Car!
« on: July 27, 2012 - 12:41:56 PM »
So the Grille I have on my 70 Cuda is in fairly good shape. There has been a small repair done to it but now that I have the car in my garage I have found that the tabs that the bezel pieces mount to have been broken off on the top of the Grille.
Has anyone made new tabs and used epoxy to affix them by pushing them through and epoxying them in?
curious,
Bryan
Offline Travis72
Re: Ye old Grille Question...
« Reply #1 on: July 27, 2012 - 11:11:24 PM »
Do you still have the tabs?  If so you can epoxy them back on and back it up with aluminum.  Just get some aluminum stock from Home Depot or someplace like that.
Travis
72 Cuda
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: July 27, 2012 - 11:58:45 PM »
That's precisely the problem, I don't. Either make them or buy a new grille altogether.
ughhhh :banghead:
Travis
72 Cuda
Offline Travis72
« Reply #3 on: July 28, 2012 - 02:17:55 PM »
Do the tabs show when the grille is installed?  Since the tab is strucural, I would bond in some aluminum stock then build up the surface with lots of epoxy, sanding and shaping to make it look like it's supposed to.  If the rest of the grille is nice it's worth a shot.
I had a big hole in my grille and I was able to fill the area with epoxy and a mesh mat.  Here's some examples of the repairs I made on my grille.
Travis
72 Cuda
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: July 29, 2012 - 03:51:51 PM »
Yeah I may give it a go since I need about 8 of the tabs on the top.
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: July 30, 2012 - 02:01:37 PM »
Travis
72 Cuda
Travis,
What kind of epoxy did you use?
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline Giveitawack
    • ebay
« Reply #6 on: July 31, 2012 - 12:45:25 PM »
I used stainless or brass sheet metal and a Bondo-like, hard filler. Sticks surprisingly well to the grille plastic. Repaired countless places with this method. Have not seen one crack after 6 years.
