Author Topic: Won't start with key  (Read 1399 times)
Offline Marty73
  • '73 Challenger
« on: July 28, 2012 - 08:33:05 PM »
High Gang.....groveling to the all mighty board again to assist with my resto!
So here's the senario, car won't turn over/start with the key. I can turn it to the on position and jump the fender cellinoid and it will start right up and run. I replaced the starter module about 5 years ago when I started the resto and it worked fine then. I rarely start it up, but did so tonight because I rebuit the carb and wanted to make sure everything was good. I did bypass the fusabile link with still no joy.
So any ideas? Could it by my iignitian module/cellinoid or something else?
Any suggestions are appriciated!
Comin' at ya like a herd of turtles
Offline BS CUDA
Re: Won't start with key
« Reply #1 on: July 28, 2012 - 09:35:44 PM »
:dunno: Neutral safety switch plugged in?
« Reply #2 on: July 29, 2012 - 12:54:39 AM »
Start relay on the inner fender or the NSS switch on the trans , the simple test is to ground the terminal the small brown wire connects to & see fi ti starts with the key , also test the small yellow wire for power in the start position
« Reply #3 on: July 29, 2012 - 03:23:17 AM »
Do you have the linkages that come off the steering column on the firewall side down to the tranny? Mine did't and it wouldn't start untill the lever that those linkages should hook to was in the correct position? Down I think?
Offline Marty73
  • '73 Challenger
« Reply #4 on: July 29, 2012 - 04:08:55 PM »
Ahhh...well now I feel a little silly - I actually pulled all the wiring out of the car and still haven't put all the harnesses back in...Neutral Safety switch I bet. I'll try that tonight!
Offline Marty73
  • '73 Challenger
« Reply #5 on: July 29, 2012 - 06:19:51 PM »
Okay...getting frustrated....I have searched under the car, around the consol shifter and cannot find the switch. Where is it physically located
Thanks!
Offline BS CUDA
« Reply #6 on: July 29, 2012 - 06:36:11 PM »
Thanks!
 Assuming you have an automatic /  727 transmission.
 Drivers side of transmission right beside the shift rod - 3 round prong switch.
« Last Edit: July 29, 2012 - 06:38:55 PM by BS CUDA »
Offline Marty73
  • '73 Challenger
« Reply #7 on: July 29, 2012 - 09:25:36 PM »
I'll go back and look  - I ended up grounding the "G" lead on the starter realy and that worked. Will need to get it fixed prior to putting the old girl all back together. Thanks to everyone!
