Author Topic: hurst shifter question  (Read 620 times)
Offline jackie
« on: July 30, 2012 - 10:14:14 AM »
I picked up a new or (a great job of a rebuild) of a shifter. It looks like ,and was tolded it was a e- body. Now that i got it home i noticed that the shifter rod holes are 1/2" instead of 3/8ths. Now can i get the rods with 1/2" on one end and 3/8th's on the other? Did the factory have both sizes at different years??
1970 challenger r/t, prostreet 438 ci. 4 speed
Re: hurst shifter question
« Reply #1 on: July 30, 2012 - 10:50:17 AM »
If the shifter is similar to mine, you just need the bushings for the shifter. My Super shifter has 1/2" holes as well. They are a separately available item.
Offline jackie
« Reply #2 on: July 31, 2012 - 07:15:44 AM »
Thanks, i did not think that the bushings would take up that much room. I also has a super shifter. I am deciding which one to use. I would guess that you make your own shifter rods? Any pictures??
« Reply #3 on: July 31, 2012 - 05:03:37 PM »
all the rods are available from different suppliers , start With Dave @ Roseville
Hurst has a bushing & spring clip set
Offline Jamiez
  • Retro
« Reply #4 on: July 31, 2012 - 05:13:46 PM »
http://www.brewersperformance.com has a lot of 833 parts, probably has what you need, but they might not be the cheapest source and their online ordering is lacking.
