Author Topic: Hooking Up My New Quincy Compressor  (Read 1470 times)
Offline daveh
« on: July 31, 2012 - 04:34:14 PM »
Hey guys,
I'm real excited I just had my new 5 horse, 60 gallon Quincy compressor delivered Friday.  I do have a question though. My previous compressor was a 7.5 horse 80 gallon Campbell Hausfeld which I never had an issue with and was about 10 years old. Long story my neighbor wanted it back.
Obviously my electric panel was hooked up correctly with the black and red to the breaker in the panel and then the ground since it's been working fine for 10 years.  I figured the hook up would be the same. However the directions seem to be a little different. I'm sure it's because it's newer. So I just wanted to make sure I got it right. I've attached a copy of the directions along with a picture. It looks like I splice my red wire into their red covered (white) wire.  This covered red wire is seperate and coming from the motor.  And then attach my black wire to the far left screw terminal after I attach a wire spade to my black wire. Then the ground. Do you guys see anything different? Am I missing something? Thanks
Offline daveh
Re: Hooking Up My New Quincy Compressor
« Reply #1 on: July 31, 2012 - 04:45:32 PM »
Here's the directions
Offline 72cudamaan
« Reply #2 on: July 31, 2012 - 05:36:04 PM »
I read the directions as showing connect the black wire to the far RIGHT terminal. Or did I
read it wrong.  :dunno:
If I cant fix it, it's broke
Andy  (phukker whither)
Offline daveh
« Reply #3 on: July 31, 2012 - 05:58:45 PM »
I think you read it wrong in the lower right picture it shows a dotted line going to the left screw indicating that the one power wire should be screwed to it.  I think that's whay I'm asking.  Thanks
Offline 422STROKER
  • Member Since 6/3/06
« Reply #4 on: August 02, 2012 - 09:08:06 PM »
Sounds/looks like you got it right.  Usually both legs are switched through the pressure switch but switching one is ok too.
Tom :2thumbs:
Tom
Offline daveh
« Reply #5 on: August 02, 2012 - 11:26:05 PM »
Thanks Tom I appreciate it.
Offline 422STROKER
« Reply #6 on: August 03, 2012 - 08:28:12 PM »
No problem, I assume you got it running ok?  How do you like it?
Tom
Tom
Offline daveh
« Reply #7 on: August 04, 2012 - 10:08:04 PM »
It's awesome.  So much quieter than my last one.  A very solid compressor, I think it going to be around a long time.  Pumps up really fast as well.  Thanks again.
