Author Topic: 1970 Challenger - K-Frame, Motor Mount Issue..  (Read 1470 times)
Offline 72ls5fla
« on: August 01, 2012 - 07:06:43 PM »
Hey all ...
I have a very intersting thing goin on ...
On the DVR side, the bolt hole for the motor mount bolt in slightly elongated.
I am guessing this is to aid in alignment when installing the engine, to give soem "play" for mounting.
Here is what is going on..
I noticed that when I would (in 1st low) slam the gas, I would hear a loud bang and noticed the shaker bubble sharply roll over hard to the thud.
I figured maybe a bad motor mount.
Turned out that the engine was lifting the motor mount up until the bolt would hit the top of the elongated slot/hole.
Now this does not happen when just in 3/drive, must not be as much torgue or something,just in 1st.
I tighted the hell out of the bolt, worked okay for alittle bit and then the same thing started again.
How in the hell can I fix this short otf chaining the damn thing down??????
Could I have a bad bolt?
really confused on this.
bill
Re: 1970 Challenger - K-Frame, Motor Mount Issue..
« Reply #1 on: August 01, 2012 - 07:17:54 PM »
Humm that shouldn't be happening as I'm sure you know. Are you sure the mount isen't seperated?
Maybe you should invest in one of these? I have one in mine and it works great!
http://www.engine-swaps.com/Pages/ProductsType/TorqueStraps.html
Offline 72ls5fla
« Reply #2 on: August 01, 2012 - 07:22:09 PM »
the mount is not seperated.
I had a buddy do a power brake while I watched, I actually saw the whole mount pull up, bolt and all.
The PASS side has a regular old hole.  It is just big enough to get the bolt through.
Wish the DVR was the same.
Maybe the motor mount is shot under side where I can't see.
Thanks for input.
Offline BS CUDA
« Reply #3 on: August 01, 2012 - 08:25:22 PM »
Torque strap indeed. I took Brads advice on this strap - works great, fits great. The car also doesn't twist as much when leaving the line.
« Reply #4 on: August 01, 2012 - 09:50:29 PM »
Try putting a jack and a 2x4 under the side of the oil pan and jack up to see what happens?  You should be able to quickly see if the mount is bad?
Offline 72ls5fla
« Reply #5 on: August 01, 2012 - 09:58:30 PM »
i will give that a try tomorrow.
i have a feeling it is going to be okay ---  but i would actually be happy if was bad.
will report back and let ya know...
