Author Topic: Synthetic oil and denial  (Read 1197 times)
Offline Perry
« on: August 02, 2012 - 07:51:59 PM »
Search engine here didn't yield tons of result for me. But Think I already know the answer to this.
I have a high mileage 440. Lots o miles but it is clean internally and serviced well. During the last tune up I put in Mobile 1 synth oil instead of the regular stuff. 10-30 like I always use. Warmed the engine and drained the old stuff out the best I could. Prefilled the new filter, etc.
About 15 minutes into the test drive and the motor started rapping pretty well. Not sure if it is a rod bearing or lifter or whatever. Still runs good and if I was deaf I would have thought wow, this is great. I searched around the internet and read various articles where people say this happened to them. Read a lot of articles where people have had no problems.
So the denial part. If anyone else told me this story I would say. Yeah, makes sense, your engine is ancient and the synth cleared away some sludge and exposed problems that were already there lurking. I did the knee jerk reaction and put regular oil back in and the noise was reduced quite a bit but the rap is still there. Muted but it stands out like a jack hammer on my brain.
So is there any thing to this? Read a lot about zinc content and impact on flat tappet cams but there is a lot of conflicting info.
Also, any suggestions on where I should investigate? The noise is only prominent when I am cruising and feathering the throttle between accel and decel. That soft spot. No noise during accel or decel.
Perry
« Last Edit: August 02, 2012 - 07:53:56 PM by Perry »
Re: Synthetic oil and denial
« Reply #1 on: August 02, 2012 - 11:30:25 PM »
New oils are designed for new engines , the government wants old engines off the road .
start with valve train , you can pull the lifters with a small strong magnet through the head without removing the intake , just the valve covers , rockers & pushrods .  I assume the oil pressure is the same as before ?
The brgs should not care what oil is used as long as there is a supply of oil there .
Offline Perry
« Reply #2 on: August 03, 2012 - 12:13:22 AM »
Thanks for the response. I didn't know that you could pull the rockers without taking off the manifold. I looked under the valve covers and found nothing interesting. So what would a guy be looking for when inspecting the lifters? Outside of the usual visual damage?
My oil pressure was a bit higher with the synth but now it is back where it started around 40-60 psi although it drops to 15-20 at idle.
Perry
Offline shadango
« Reply #3 on: August 03, 2012 - 08:52:16 AM »
" you can pull the lifters with a small strong magnet through the head without removing the intake , just the valve covers , rockers & pushrods .
I didnt know this either.....  :clueless:  How is that possible?  The lifter wont fit up thru the pushrod seals.......??? Or is this just on this particular motor??
« Reply #4 on: August 03, 2012 - 09:54:49 AM »
the gaps between the ports on the heads easily allow a lifter through , small block is a bit tougher but you can feed the lifter through the adjacent gap & move the lifter over to the lifter bore . I have a small magnet that will lift a 1/2 drive rachet or more & a long thin screw driver , I slide the lifter into place with the magnet & hold it with the screwdriver while I remove the magnet when I re-install the lifters .
Offline dodge freak 2
« Reply #5 on: August 04, 2012 - 08:28:49 PM »
yep, I have swap cams before without removing the intake. Mopar rules in more ways then one
« Reply #6 on: August 04, 2012 - 09:36:39 PM »
 :thumbsup:
