XV lower rad support question..
Author Topic: XV lower rad support question..  (Read 9124 times)
Offline TROUBLE987
« on: August 02, 2012 - 10:52:16 PM »
Is their anyone running this?if so how does the radiator fit in the car with it? Also do you completely remove the lower sheet metal?
Offline gkring
Re: XV lower rad support question..
« Reply #1 on: August 03, 2012 - 12:08:13 AM »
Basically if you keep the factory lower piece you have to have a side tank aftermarket radiator. To use a factory top and bottom tank unit you have to remove the lower sheetmetal piece and install their brace with the two little extensions that come with it to drop it lower.
http://www.cuda-challenger.com/cc/index.php?topic=31233.msg312868#msg312868
Greg
1970 Barracuda driver
Offline grimmey71
« Reply #2 on: August 03, 2012 - 12:42:25 AM »
 :banghead:
Always wondered what those two pieces were for lol
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #3 on: August 03, 2012 - 06:26:46 AM »
I am
For the best fit you would could remove the lower section. If you were worked about the look you could then reinstall it over the new brace. I slid my brace back just enuf to weld it in on all 4 sides.
Go Fast & Have Fun...
Offline Haddixj
« Reply #4 on: August 03, 2012 - 10:24:32 AM »
My lower rad support has been cut already so I am plannin on adding one of these. Does it span the front frame rails? What size box tubing is it made of? Xv is showing out of stock currently
Offline smallblocksrock
« Reply #5 on: August 03, 2012 - 11:34:49 AM »
I used the XV product on a 70 challenger two years ago.  It made a huge difference in the flex of the car which is real apparent when you jack up a front wheel.
I removed the stock support and welded in the brace with the front edge of the brace 2.5 inches from the front of the frame rail.  The short extensions are required if you are using a stock radiator.  You also need to weld in a plate for your vertical support.
Since the product has been out of stock for a long time, I made my own for a 73 barracuda project by welding up 2" stock.
I have photos, but they are way over the 300kb posting limit.  PM me if you like.
Offline TROUBLE987
« Reply #6 on: August 03, 2012 - 12:03:18 PM »
If I add this (which I probably will) what radiator is fitting good?.I'm running a big block..
Offline cudazappa
« Reply #7 on: August 03, 2012 - 02:16:54 PM »
I would be interested in seeing this.  Been thinking about finding an xv brace and cutting it so it stays at the stock location ( not using their "spacers")
2015 Dart GT - Daily Driver
« Reply #8 on: August 03, 2012 - 10:31:47 PM »
I had a lot of requested for images, so here they are.
Offline Haddixj
« Reply #9 on: August 03, 2012 - 10:48:21 PM »
What did you use to bend the tube? And not have it kink
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
« Reply #10 on: August 03, 2012 - 11:05:36 PM »
So why has the XV brace been on galactic back order? Hasn't it been over 4 months? I was hoping to pick this and their subframe connectors up at nats.
« Last Edit: August 03, 2012 - 11:07:11 PM by YellowFin »
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
« Reply #11 on: August 03, 2012 - 11:18:49 PM »
The photos are of the XV product which is smooth.   When I did the Barracuda, I cut wedges into 2" stock, bent them together,  then welding them back up.   The curve is not as smooth as the XV design.
Regarding XV.  They state out of stock, which may be defined differently than back order.  My guess is that there is not much margin/profit in the product.   If you have the capability to weld then in place, you have the capability to make them yourself.
Offline berna4406
  • Sinister
« Reply #12 on: August 04, 2012 - 12:36:39 AM »
Anyone looking to buy XV Level 2 for a big block?We just pulled one out and switched to Alterkation.Let me know Sam
erktion.Let me know
Offline autodynamics
« Reply #13 on: August 04, 2012 - 12:51:38 AM »
Look fellas although any bracing is good the radiator support made a little difference but certainly not tremendous
The engine brace I put in with conjunction with the rad support made a 100%
Difference
Prior to the engine brace a actually cracked a aluminum radiator
Due to flexing
After the engine brace went in is was immediately apparent it made a difference after
Pulling out of the driveway
My car handles proof positive
If you haven't looked into the brace do so
There is no pumping up of the info it made a HUGE DIFFERENCE !!!
14k later she's tight
    • THE DODGE BOYS
« Reply #14 on: August 04, 2012 - 06:00:58 AM »
Difference
Due to flexing
Are you talking about a triangle brace above the motor tying the fenders and firewall together?
Did you reinforce the firewall behind mount or plate it?
« Last Edit: August 04, 2012 - 06:02:48 AM by thedodgeboys »
