Author Topic: XV lower rad support question..  (Read 9125 times)
Offline Cuda416
Re: XV lower rad support question..
« Reply #15 on: August 04, 2012 - 10:18:21 AM »
Here is a nice alternative way to build that brace. In fact, everything this guy does is pretty amazing..
http://www.cuda-challenger.com/cc/index.php?topic=77214.0
C
70' Barracuda conv. (project)
Offline cuda346pk
« Reply #16 on: August 05, 2012 - 01:52:08 AM »
I used the us car and tool one, left my stock brace in place and tacked to it as well.
https://store.uscartool.com/
David - In Georgia
1972 'Cuda In-Violet 340 6 Pack 4 Speed 3.91 Sure Grip - Finally, after 27 years of waiting and dreaming it is real. Now the fun begins!
Offline TROUBLE987
« Reply #17 on: August 05, 2012 - 03:00:15 AM »
Well just so everybody knows I talked to xv and they do have the braces in stock.But they have a cosmetic issue with them..I got one on the way..ill post pics soon to show you what I get..also they are knocking some money off if you are wanting one..just a heads up and thx for the info..and pics
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #18 on: August 05, 2012 - 08:15:51 AM »
I made one from 1 3/8 DOM tube . They are not too hard to make .I too mounted it behind the original brace
Offline autodynamics
« Reply #19 on: August 05, 2012 - 12:49:11 PM »
Are you talking about a triangle brace above the motor tying the fenders and firewall together?
Did you reinforce the firewall behind mount or plate it?
Yes ! The firewall was reinforced inside using plates once bolted in, you can lift the car from it.
That is a fact the brace made a much bigger difference than the rad support and sub frame connectors combined
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
« Reply #20 on: August 05, 2012 - 02:19:47 PM »
Cosmetic issues? I wonder what that means.
Also, what kind of discount are we talking here?
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
Offline TROUBLE987
« Reply #21 on: August 05, 2012 - 08:01:38 PM »
When I spoke with the guy,he said the bends had a slight ripple but everything was straight..I want to say he knocked 20 dollars off..when I get it in I'll post some pics..
Offline pywell
  • Autobody Technician
    • PPC Customs
« Reply #22 on: August 08, 2012 - 04:55:09 PM »
Anyone have pics of this triangle engine support? And is this rad stiffening support highly recommended for the 6.1 conversion?
Offline diyhemi.com
    • DIYHEMI.COM
« Reply #23 on: August 08, 2012 - 08:54:08 PM »
$75 to $95 seems like a ridiculous amount seeing as it is only 2x2 square steel tubing with 2 bends in it. You can find 72" sections of that tubing for $20 all over the Internet. I figure you would only need about 36" of stock metal per brace, and that includes what is wasted due to the bender needing enough material to bite onto which is later trimmed off. with some measurements, I bet a local metal shop could make you one for $40 out the door, with them making decent profit on it. Just my 0.02.
« Reply #24 on: August 10, 2012 - 12:32:52 AM »
Yes , it's a triangulated one , and yes the firewall was reinforced
MAJOR IMPROVMENT !!
Offline b8fish
« Reply #25 on: September 19, 2012 - 09:01:24 AM »
Hey guys, Here's a couple of shots of the XV brace on my 'Cuda. I opted out of the rad support . Went with the frame ties too.
Offline willhaven
« Reply #26 on: September 20, 2012 - 12:01:55 PM »
I have the XV radiator brace, tubular fender apron braces, and the form fitting subframe connectors installed. I didn't go with the engine compartment brace because I have a 440 six pack setup and they told me it wouldn't fit.
The lower radiator brace on my car was installed by removing the original metal. I have an aluminum radiator, the A/C condenser in front of it, and the A/C drier in front of that. It all fits.
« Last Edit: September 20, 2012 - 12:06:42 PM by willhaven »
