Author Topic: Modiified Suspension Combinations for Handling and/ or drag racing  (Read 21393 times)
Offline Simple
Re: Modiified Suspension Combinations for Handling and/ or drag racing
« Reply #15 on: May 19, 2015 - 08:36:18 AM »
What rims are those? Looks great!
Entry/Update Date: 8/6/12
Model: Dodge Charger
Year: 1969
Total Weight: w/ wo  driver? :
4 corner weights if possible:  LF              RF
                                               LR              RR
Application: (Show, Daily Driver,  Autocross, road cource, Dedicated Race car, Drag ? ) Driver
Engine Package briefly: 440, 800cfm carb, performer RPM intake, mild cam, TTI exhaust
Estimate HP: FW or RWHP: 400?
Trans: 727
Speed:
Gears:
Rear end  Ratio: 3.55
Rear end Type: Sure Grip, Detroit, Spool, Open , Dana 60, 8 3/4? 8 3/4 sure grip
Front Tire Size Brand Model: BFG  Gforce KDW2 245/40/18
Front Rim width: 8
Rear tire Size Brand Model: BFG Gforce KDW2 285/40/18
Rear Rim Width: 10
FRONT SUSPENSION
Aftermarket Front End brand: Hotchkis TVS setup
Coil Rate:
Front Shocks: Edelbrock IAS
spindle type? , stock/aftermaket? : 73 A body
aftermarket front hubs? : Wilwood
Front Sway bar Dia: 1 3/8"
Torsion bar diameter: 1.03"
Bump steer measurements:
REAR SUSPENSION
Aftermarket rear suspension brand: Hotchkis TVS setup
Coil rate:
Shocks:
Rear Leaf Suspension brand/ Rate: Hotchkis 160lb rate
Rear Sway bar Dia: !"
Front Brakes: Wilwood
Rotor Dia Width: 10.75
Caliper-Pistons: 4 piston
Brake pad brand: Wilwood
Cooling Ducts:
Rear Brakes : Drum
Drum Size Dia Width: 11
Rotor Dia:
Rotor width:
Brake pad/shoe brand:
[b} Caliper- Pistons :
Master cylinder brand/application: Wilwood
Master cylinder diameter: 7/8
Stock pedals y/n : yes
Power brakes y/n : yes
 type ? hydroboost, stock?: Hydroboost
Manual brakes:
Chassis
Subframe Connectors: Hotchkis
Torque Boxes:
Roll bar, Roll Cage:
Aftermarket stiffeners:
Comments:
1. Best above improvement: Hydroboost
2. Least effective above improvement:
3.Future upgrades? 13" Baer brakes front and rear, gear vendors overdrive, and aluminum heads
4. Above car handles IMO on a 1-10 ( 10 best Viper, 1 stock): 6
