you will need a gasket , the axles are the same & will work fine , the difference if any will be the yolk size for the U joint , there are 2 sizes , the 7260[2 1/8" inside the ears] & 7290 [2 5/8"] the 741 used the 7260 U joint , the 742 & 489 can have either size yolk
