Author Topic: Buffing 30 year old Lacquer  (Read 1123 times)
Offline tx9aarcuda
« on: August 05, 2012 - 08:36:36 PM »
I had my Coronet painted back in 1982 and it is need of some TLC. What do you guys recomend a novice use to buff the paint, it is not oxidized but has a lot of light scratches.
« Last Edit: August 05, 2012 - 09:33:20 PM by tx9aarcuda »
Greg
68 Coronet R/T Convertible 4 spd
70 AAR Auto
97 Ram 1500
Offline footin70rt
Re: Buffing 30 year old Lacquer
« Reply #1 on: August 06, 2012 - 12:01:08 AM »
My Challenger was repainted in the early 80s also. It had light to moderate oxidation and small surface scratches, I used Meguiare's ultra cut compound (105) and a DA polisher followed up with their cleaner wax. It's not a base/clear shine but pretty good for a 30yr old cheap single stage paint job.
If you can find a Meguiare's or Mother's rep in your area, sometimes they will be willing to use you vehicle for a demo and the you get it done for free. A friend of mine got it done a couple of years ago.
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline stinger
« Reply #2 on: August 06, 2012 - 10:57:29 PM »
depending on how bad I would use 3m perfect-it II and a wool pad fowllowed by perfect-it black polish and black foam pad and then a blue pad with swirl remover. then wax it.
lacqure is a pain to keep up.
Offline elitecustombody
  • Supra collector
« Reply #3 on: August 13, 2012 - 12:37:10 AM »
I cringe of even a thought of using wool pad near any car. Wool pads belong in trash
Stefan B
Offline LAA66
« Reply #4 on: August 13, 2012 - 08:49:29 AM »
 One thing to be cautious of is making sure everything is clean during the buffing process. If abrasive are picked up from the previous step there will be small swirls that require additional effort to remove. Final cleaning of the compounds from nooks and crannies can leave scratches also.  :2cents:
Offline tx9aarcuda
« Reply #5 on: August 22, 2012 - 10:00:42 PM »
Thanks for the tips
Greg
70 AAR Auto
97 Ram 1500
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #6 on: August 23, 2012 - 04:08:29 AM »
First I would use a clay bar to remove any debris in the paint before doing any type of buffing.  Mother's or Meguiars, it's your choice.
Mothers Polish - Using Clay Bar (How To Video)
Car Claying
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
