Author Topic: Proper firewall install hardware  (Read 908 times)
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« on: August 05, 2012 - 09:08:53 PM »
Hey all,
What is the proper hardware to attach the voltage regulator, ballast resistor, and ecu on the firewall? I have the original hardware that was on there but it doesn't seem right. The resistor was being held on by a long screw (blade) with very course threads. The bolts that held the voltage regulator (2) were different sizes. The ECU is for an electronic ignition upgrade and I need to drill for those.
Thanks.
Re: Proper firewall install hardware
« Reply #1 on: August 05, 2012 - 09:16:24 PM »
Here are the correct fasteners.  There were two different head markings on mine.  The ones in the picture say I/S.  The others I found had an anchor head marking.  They are clear zinc plated and take a 7/16 socket.
« Last Edit: August 05, 2012 - 09:19:35 PM by burdar »
Offline peterro
    • The Pistonhead
« Reply #2 on: August 06, 2012 - 01:24:57 PM »
Thanks. Is that the same type of bolt for the ballast resistor?
« Reply #3 on: August 06, 2012 - 01:26:41 PM »
No, the ballast used a much longer and thinner bolt.  I think it has a 5/16 head on it.
Offline Jamiez
  • Retro
« Reply #4 on: August 06, 2012 - 05:18:24 PM »
I believe this is the ballast:
Offline Grec
« Reply #5 on: August 07, 2012 - 11:49:57 AM »
Starter relay (x2), Voltage Regulator (x2) ECU mounting bracket (x2) ECU to bracket (x2)
I believe there are a couple more in my engine bay, holding a block off plate of some kind, but can't recall for sure.
All should be the anchor head screws. RT specialties has them and they are nearly dead-on to the stock ones. Aside, of course, from the new zinc finish. :-)
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
« Reply #6 on: August 07, 2012 - 12:53:18 PM »
the original ballast used the same kind of bolt , the repro ballasts are nto made the same , original had a brass strap around the ballast new ones need a longer bolt to go through the ceramic
