Author Topic: Electronic ignition  (Read 1857 times)
Offline cameron2502
Electronic ignition
« on: August 05, 2012 - 10:27:11 PM »
I have a 71 cuda and put the chrysler electronic ignition on, sometimes when i shut it off it wont restart (Always when engine is hot) and it has no fire to the plugs, when it cools down it starts right up, i have heard that the orange ignition box,s are not good which is what i have, i'm going to order another box which one should i get.
Re: Electronic ignition
« Reply #1 on: August 05, 2012 - 11:07:43 PM »
Some people have been having issues with the chrome boxes now too.  Personally, I'd just go to your local parts house and get one from them.  It's probably only $20-$30 and might have a warrenty with it.  At least you'll know if your orange box is the issue.
« Reply #2 on: August 06, 2012 - 12:02:33 AM »
it could be a bad coil or pick up in the dist also
 the coil is easy to test just jump power to it & disconnect the ground  it should spark everytime
Offline footin70rt
« Reply #3 on: August 06, 2012 - 12:30:16 AM »
I recently just had a pick up coil fail in a new Mopar Performance distributor with less than 100 miles on it. Don't overlook  things just because they are new.
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
« Reply #4 on: August 06, 2012 - 10:55:43 AM »
You may want to look at the new Rev-n-nator ecu with rev limiter
Offline cameron2502
« Reply #5 on: August 14, 2012 - 10:00:28 PM »
dont know what the air gap is suppose to be on the pickup coil, looked to be to wide so i set it with a business card, card measured .012 and it starts good cold and hot, i did buy a Rev-n-nater but i have not installed it yet, maybe it will help my shakey idle, thanks for the help
« Reply #6 on: August 14, 2012 - 11:39:49 PM »
Gap is .oo8 so you are close
