Author Topic: Hide electronic ignition  (Read 605 times)
Offline Nel
« on: August 06, 2012 - 10:11:19 AM »
I looking to do a conversion from points to electonic on the 1970 Challenger and I dont want it to be visible. Other then pertronix is there an other option? From the search I did, it look like some of you had problems with pertronix.
Re: Hide electronic ignition
« Reply #1 on: August 06, 2012 - 10:49:54 AM »
Well I bolted the ECU under the battery tray , you could try the new revanator box with built in rev limiter , had to extend the harness to reach . Not really a fan of the Pertronics , you Must run power to the ballast not the coil for it to work , the coil only gets 6-8 v
