I see you made some modifications, (5 speed transmission). Are you running an electronic ignition or the standard breaker points? If you are using the Chrysler ECU ignition, your engine compartment won't look original, but, somebody can post pics from a 1972 'Cuda and you will know where to install the ECU box with bracket. I will lokk in my books to see if I can scan something for you.
Robert
