Author Topic: Do-It Yourself Yellow zinc dichromate  (Read 4624 times)
Offline Mopar_Mudder
  • I'm a llama!
« on: August 07, 2012 - 04:00:20 PM »
Has anyone tried this from Eastwood:
http://www.eastwood.com/ew-golden-cad-gold-base-step-1-14-oz.html
Or know of another way to paint the wiper motor the correct color?
1971 Hemi Cuda
2005 SRT-10 Regular Cab Flame Red.   12.771 @ 109.67 <-----Time Slip --Video
Mopar: Headers, Exhaust, Ram Air, ECM
2008 3500 Mega Cab Dually, Resistal Edition
Re: Do-It Yourself Yellow zinc dichromate
« Reply #1 on: August 07, 2012 - 04:11:09 PM »
There are zinc platers all over the place.  Check the yellowpages.  Zinc plating is pretty cheap.  They usually have a minimum charge so gather all your nuts and bolts that need plating and get them done all at once.  Muruatic acid will remove all the old plating/rust very quickly and the fasteners will be ready for plating.
  • I'm a llama!
« Reply #2 on: August 07, 2012 - 04:22:21 PM »
The other problem is that at one point in time the motor got sand blasted, so I am not so shure that the translucent look of yellow zinc is going to work real well any more. Does anyone sell just the outer motor housing ready to go?
1971 Hemi Cuda
« Reply #3 on: August 07, 2012 - 04:26:26 PM »
You might want to give fellow member Kim a shout.
  http://www.cuda-challenger.com/cc/index.php?topic=65631.0
« Reply #4 on: August 07, 2012 - 05:05:44 PM »
Without seeing the housing I can't answer for sure.  You should be able to sand it to a smooth finish.  Plating won't hide any pitting.  The metal has to be smooth.  I'd have yours replated or contact Kim about a different  part.  I would not paint it.  It won't look right. :2cents:
  • I'm a llama!
« Reply #5 on: August 07, 2012 - 05:30:11 PM »
I am going to check it out tonight and make sure the motor is even good before I go any further with this.
Anyone know if Kim will sell just the plated motor housing alone? I will contact and ask after I found out the condition of the motor, just thought someone might know if she does.
1971 Hemi Cuda
« Reply #6 on: August 07, 2012 - 11:48:03 PM »
Kim is awesome to deal with , she will do just about anything to help .
« Reply #7 on: August 07, 2012 - 11:54:50 PM »
 :2cents:
Send out to anodize. Rattle can imitation look just won't cut it.
Offline Jamiez
  • Retro
« Reply #8 on: August 08, 2012 - 06:31:01 PM »
They do sell a Tin-Zinc electro plating kit...batteries, chemicals, etc
http://www.eastwood.com/ew-electroplating-system-tin-zinc.html
Doesn't look like you can get the gold cad finish tho
Offline FJ5_440
  • Wisconsin
« Reply #9 on: August 08, 2012 - 08:29:13 PM »
She is a real asset to the hobby.
** Shane **
  • I'm a llama!
« Reply #10 on: August 09, 2012 - 09:38:00 AM »
After more looking at the wiper motor decided to just get a new one from Kim. Probably would have spent around $125 or so to redo the one I have myself.
1971 Hemi Cuda
