Author Topic: Hemi Stock Fuel Line Routing  (Read 2317 times)
Offline Mopar_Mudder
  • I'm a llama!
« on: August 07, 2012 - 05:44:19 PM »
I am trying to figure out the correct stock fuel line routing for a 1971 Hemi, I have seen it done in a bunch of different ways it seems.
But from what I can tell the stock configuration would be a Vapor Seperator between the pump and the Tee. Then a seperate filter after the Tee for each carb. Is this correct?
1971 Hemi Cuda
2005 SRT-10 Regular Cab Flame Red.   12.771 @ 109.67 <-----Time Slip --Video
Mopar: Headers, Exhaust, Ram Air, ECM
2008 3500 Mega Cab Dually, Resistal Edition
Re: Hemi Stock Fuel Line Routing
« Reply #1 on: August 07, 2012 - 11:37:37 PM »
for sure on the cross ram engines , not sure on the inlne carters
« Reply #2 on: August 08, 2012 - 12:09:04 AM »
Does this help?
Offline GranCuda1970
« Reply #3 on: August 08, 2012 - 02:32:00 AM »
Thanks will work for 440 too! I was thinking it was something like that! I got all the crimps and line both 3/8 and 15/16.
  • I'm a llama!
« Reply #4 on: August 08, 2012 - 09:47:31 AM »
That does help, thanks. So is their no fuel filter at all on your set-up then? Just the vapor seperator.
What confuses me is I have an assembly diagram that shows it just like you have it. Then I have a parts book that shows filters between the tee and carbs.
1971 Hemi Cuda
« Reply #5 on: August 08, 2012 - 10:09:48 AM »
64'-67' Hemi's had the inline filters. After that year, they didn't.
  • I'm a llama!
« Reply #6 on: August 08, 2012 - 10:22:58 AM »
Got ya, so much for a "correct" parts book then.
Seem really strange to run with no filter at all, I might have to sneak one in back by the tank of something.
1971 Hemi Cuda
