Pict of center spring install on 4 speed 'cuda
Author Topic: Pict of center spring install on 4 speed 'cuda  (Read 1923 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: August 09, 2012 - 03:38:56 PM »
Anyone got a picture of the center spring installed in a 'cuda?
My speedometer cable is in the way. The service manual just don't show me how it should be installed. Anyone have a tip on how to install it. Yes the dash is in the car
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline widing'cuda
Re: Pict of center spring install on 4 speed 'cuda
« Reply #1 on: August 11, 2012 - 02:22:51 PM »
ok, now I got the center-spring installed (use a copel of screw drivers to widen the spring). The clutch pedal is a hole lot easier to push.
But now the pedal doen't go all the way up unless I touch under with my foot. How do i fix this?
« Reply #2 on: August 11, 2012 - 03:21:58 PM »
Ok the over center spring , I could not figure out what you were asking about !!
 Adjust the pushrod so it is a bit longer & the pedal will come up to the top
Offline widing'cuda
« Reply #3 on: August 12, 2012 - 09:35:53 AM »
The one I have marked out in the picture?
« Reply #4 on: August 12, 2012 - 10:17:10 AM »
yes
Offline 4Cruizn
  • HEMI FISH
« Reply #5 on: August 12, 2012 - 01:52:42 PM »
Remember not to adjust all the way to the top as you need to leave some play so the throw out bearing is not engaged all the time.
« Reply #6 on: August 12, 2012 - 02:00:29 PM »
you need to lengthen it enough so the pedal pops up but not too long , ideally you need about 1" of free play at the top of the pedal travel
Offline widing'cuda
« Reply #7 on: August 17, 2012 - 12:49:30 PM »
ajusted the nut and now the pedal pops back up. it's about 1" play
Thanks guy!
« Reply #8 on: August 17, 2012 - 01:54:58 PM »
 :2thumbs:
