Author Topic: Where do you mount your aftermarket coils on a E-Body?  (Read 4809 times)
Offline mellowguy
« on: August 10, 2012 - 03:25:22 AM »
Where do you mount your after market ignition coil on a E-body, Big Block? Any Pictures? I have a larger Jacobs Ultra Coil to mount, any suggestions?
Offline GranCuda1970
Re: Where do you mount your aftermarket coils on a E-Body?
« Reply #2 on: August 10, 2012 - 05:16:41 AM »
Like the sixpak you will need a longer coil wire for the distributor.
Offline 68-383Bee
« Reply #3 on: August 17, 2012 - 02:59:17 PM »
I have a similar MSD coil.  I made an aluminum plate and attached the coil to it using the rubber vibration isolators supplied with the coil.  The plate bolts to the valley pan hold down bolts.  You can just see the coil behind the upper radiator hose in the attached pic.
Charles
Offline ShelbyDogg
« Reply #4 on: August 31, 2012 - 02:50:53 PM »
When I used an accell super coil, I had it mounted in the space between the horns and the A/C drier on the side of the engine compartment. This is for a big block and 70 Challenger where the horns are on the passenger side front, by the washer bottle.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: August 31, 2012 - 03:40:25 PM »
I plan to mount the coil and m6al on the frame and somewhat hide it.
Btw, how come no one uses the heater control valve anymore? Guess they dont care if it flows thru the heater core all the time
« Reply #6 on: August 31, 2012 - 03:47:22 PM »
Only A/C cars used heater control valves.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: August 31, 2012 - 04:00:46 PM »
Makes sense as I deleted mine
Thx
Offline ShelbyDogg
« Reply #8 on: August 31, 2012 - 04:53:57 PM »
I use mine all of the time. When I go to cruises, it is sometimes cold when driving home at night. Nice to have a working heater.
« Reply #9 on: September 01, 2012 - 10:15:23 AM »
Might the core get plugged up if the coolant doesn't flow through on a reasonably regular basis?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: September 01, 2012 - 01:04:18 PM »
Not really, the only thing you have to worry about with the core is rusting out.
Offline 73EStroker
« Reply #11 on: November 04, 2012 - 06:11:39 PM »
I mounted my coil on the right side inner fender about in line with the front of the engine. Keeps it away from the heat. Never could understand why the coil was placed onn the hot engine as wire increases in resistance when it gets hotter therefore lower voltage on the plugs.
Barry (Salmon Arm)
Offline HP_Cuda
  • Mopar or No Car!
« Reply #12 on: November 04, 2012 - 06:52:57 PM »
I plan on mounting my 6AL on the firewall and the HVC coil just behind the horns.
Definitely don't want to raise IR because of heat and dang my coil was friggin expensive!!!
