Gen iii cable throttle bodies
Author Topic: Gen iii cable throttle bodies  (Read 2783 times)
Offline pywell
  • Autobody Technician
    • PPC Customs
« on: August 10, 2012 - 11:37:17 AM »
Im looking for a 90mm+ throttlebody for the 6.1 I started looking to see what options are out there for us and thought it would be helpful to find out what everyone else has come accross.
So far I have found the mopar 80mm one and BBK 1791 80mm.
I really am looking for high increase in cfm intake, a dual butterfly setup like the srt10 and vipers have would be a great setup too.
Sent from my SGH-I896 using Tapatalk 2
Offline Haddixj
Re: Gen iii cable throttle bodies
« Reply #1 on: August 10, 2012 - 11:17:43 PM »
I will buy the fast adapter and use an gm ls throttle body. I'm not sure what injection setup your using but I'm going with megasquirt so using the gm has its advantages. What are your plans for the motor? I think the stock 6.1l intake is only 84 mm so unless you are doing something different I would stick with that size. If your planning on a boosted motor then I wouldn't worry about the size so much.
Offline grimmey71
« Reply #2 on: August 10, 2012 - 11:31:52 PM »
Offline Travis72
« Reply #3 on: August 14, 2012 - 01:31:55 AM »
Here's a pic of the FAST adapter with the LS1 throttle body that comes with the FAST 6.1 kit.  It's a nice piece.  My only compliant is that the throttle cable is on the passenger side.  I wish it was on the drivers side and pulled from the bottom because it would be a lot easier to make a bracket.
Travis
72 Cuda
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #4 on: August 14, 2012 - 06:32:27 AM »
Bbk is supposed to be making a bigger one they have a part number for it but as usull no stock.
Maybe by the time your ready for one it will be released.
Go Fast & Have Fun...
Offline grimmey71
Offline Modern Muscle
  • Moderator
    • Modern Muscle Performance Group
« Reply #6 on: October 31, 2012 - 05:13:26 PM »
The 6.1 Intake is 84mm so anything bigger then that you need to CNC port the intake to take advantage of the larger TB. Also unless you are runner bigger cubes anything bigger then 85mm is a waste if money.
Offline grimmey71
« Reply #7 on: November 02, 2012 - 01:37:01 AM »
That's why having you guys around is great! Just wanted to say I have called you guys twice this week each spoke with some one different and each time you guys took your time explaining things and were very informative and kind so thanks.
  • Moderator
« Reply #8 on: November 07, 2012 - 05:09:27 PM »
Glad we could help  :thumbsup:
