Transmission will not shift between 1st & 2nd gear
Author Topic: Transmission will not shift between 1st & 2nd gear  (Read 2103 times)
Offline 67vertman
  • Member since 9-23-2005
« on: August 12, 2012 - 05:23:35 PM »
My A833 transmission will not shift between 1&2 gears.  It is stuck in neutral; this is with the trans out of the car. It will shift between 3&4 and into reverse.  I pulled the shifter levers of and put a wrench on the gear selector, it will move about a ¼ inch, but won’t go into first or second.
I pulled the side cover off what should I be looking for to see what is binding?  :clueless:
« Last Edit: August 12, 2012 - 05:26:06 PM by 67vertman »
Re: Transmission will not shift between 1st & 2nd gear
« Reply #1 on: August 12, 2012 - 11:03:57 PM »
Are you rotating it while doing this , is the fork bent , can you slide the syncro collar over the gear with the cover off ?
Offline 67vertman
« Reply #2 on: August 12, 2012 - 11:25:39 PM »
Thanks Neil, yes i am rotating the it, but it wont budge, it stay in nuetral, and won't engage.  The fork dosn't look bent.  I haven't tried to slide the syncro collar yet.  I will try that.  It is like the fork engage
Offline 67vertman
« Reply #3 on: August 18, 2012 - 07:02:17 PM »
The problem is solved.  :bananasmi
The issue was the 1st and 2nd  speed fork was installed backwards, with the long end towards the reverse gear, stoping it from moving.
once iI fixed that it shifts perfectly.  :clapping:
