Author Topic: Water pump  (Read 478 times)
Offline EMCD
Water pump
« on: August 12, 2012 - 05:54:34 PM »
I currently have a marches pulley kit on m 408 stroker. I want get rid of my electric fan set up and go to a mech fan. Can i just add a fan unit? Or, do i need a different pump? Can I use my original shroud from my factory radiator? I have a champion unit on it now. It was a 340 car w/o air
Re: Water pump
« Reply #1 on: August 12, 2012 - 06:53:32 PM »
The pump should just be the one you had originally. You can use your original shroud, if it fits your aftermarket radiator.    :dunno:
Re: Water pump
« Reply #2 on: August 12, 2012 - 10:50:37 PM »
I would use a clutch fan probably with the short Jaguar clutch for clearance , you can get a 18" Flex-a-lite fan
Offline EMCD
Re: Water pump
« Reply #3 on: August 13, 2012 - 07:53:12 AM »
I'll take a picture of the front of the rad and measure the distance between the rad and the w/p. I'm hoping i can use my old shroud from my original system. where can i get a jag clutch?
Re: Water pump
« Reply #4 on: August 13, 2012 - 09:56:49 AM »
Any parts store , I have been using them for years
