Author Topic: vibrations ugh. what do you guys think?  (Read 5491 times)
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
« on: August 12, 2012 - 06:07:29 PM »
ok guys need some help/advice after replacing the tranny converter getting the drivshaft balancedand u-joints replaced the car still seems to be the same when i go above 50-60+ mph i get a terrible vibe but when i deccel it grinds and clunks weird i know i dont know how to describe it ive checked the pinion angle since i have the summit 1 inch drop spring sitting at 5 degrees down and have checked the rest of the car over so im at a loss almost a reaching out to anyone who can help or give ideas ive read some of the other topics likes this and tried things but no luck what do you guys think and the car is a 70 challenger 360 with 727 with 3:55
james
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
Re: vibrations ugh. what do you guys think?
« Reply #1 on: August 12, 2012 - 06:48:19 PM »
It's weird that it only does this on deceleration.  Are you applying the brakes at this point?
« Reply #2 on: August 12, 2012 - 07:20:30 PM »
Did you replace those parts to eliminate the vibes or did the vibration show up after they were changed? Ill asume you replaced the converter with one for the externally balanced 360?
Offline calicuda70
« Reply #3 on: August 12, 2012 - 08:32:21 PM »
no just letting it coast down.
70 Challenger 360
Offline calicuda70
« Reply #4 on: August 12, 2012 - 08:34:22 PM »
i replaced them to hopefully stop the vibration but no luck lol, and yes it the externally balanced converter im also running the b&M half moon flex plate for it.
70 Challenger 360
« Reply #5 on: August 12, 2012 - 09:00:20 PM »
You said 5 degs on the pinion angle. What angle is the trany motor at? I'm wondering if this is the problem? :dunno:
« Reply #6 on: August 12, 2012 - 11:06:20 PM »
are the U bolts tight I wounder if the diff is changing angle , are the seat on the axle tubes welded properly . Any problems with the gearset ?
Offline calicuda70
« Reply #7 on: August 13, 2012 - 01:28:12 AM »
yea 5 down also running poly mount on the motor and trans, what angle should the tranny/motor be sitting at and do i just put the angle finder on the tailshaft?
70 Challenger 360
Offline calicuda70
« Reply #8 on: August 13, 2012 - 01:32:05 AM »
u bolts are tight, axle seems to be fine i have another ebody rear end with 4:10 i thought about putting in just to check and see if anything was wrong with my current axle but i cant see anything and the gears were replaced last year and was doing it before i put them in.
70 Challenger 360
« Reply #9 on: August 13, 2012 - 08:21:08 AM »
I always thought it was good to shoot for 3 degrees?   More if it's a drag car? Some say 5-7? Do a google search on it , lots of info?
http://www.hotrodhotline.com/md/html/drive_shaft_harmonics.php
http://www.moparts.org/Tech/Archive/axle/8.html
« Reply #10 on: August 13, 2012 - 08:49:38 AM »
Yes. I removed the yoke and measured off the face of the tailshaft. I think Sledgehammer recommended that method to me.
« Reply #11 on: August 13, 2012 - 08:53:34 AM »
Did you check/rebalance the wheels?
« Reply #12 on: August 13, 2012 - 08:56:40 AM »
Rear axel bearing?
« Reply #13 on: August 13, 2012 - 09:49:50 AM »
BFG tires are never round
Offline calicuda70
« Reply #14 on: August 13, 2012 - 12:22:28 PM »
thanks for the link brad gunna get some wheel ramps and put her up this weekend and check all that stuff.
70 Challenger 360
