Author Topic: Stainless Window rails  (Read 2568 times)
Offline HP_Cuda
  • Mopar or No Car!
« on: August 13, 2012 - 02:48:19 AM »
After sending many a part off to a chrome shop, I got back my window channel rails which install to the inside upper portion of the window.
When I took them in I noticed they looked like they had a gasket attached to them. Anyone know where I can find a pair so I can put them back in my 70 Cuda?
Thanks!
Bryan
Re: Stainless Window rails
« Reply #1 on: August 13, 2012 - 09:23:14 AM »
You had the drip rail trim chromed?  It's stainless from the factory and only needs to be polished.
Yes, there were gaskets in that area.  There is a gasket between the drip rail trim and the body as well as between the weatherstripping holder and the drip rail trim.  Detroit Muscle Technologies makes the kit.  A lot of other companies sell his stuff.  You can get it dirrectly through him or through one of the many venders that sell it.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: August 13, 2012 - 12:03:22 PM »
No everything was just polished, looks good too!
Yep looking for the gasket between the rail and the body. I got the weatherstrip kit from yearone but I don't know if it has it.
Is there a name for this gasket so I can check?
Thanks!
Bryan
Offline HP_Cuda
  • Mopar or No Car!
« Reply #3 on: August 13, 2012 - 12:06:36 PM »
Is this what I am looking for?
70-74 E body & 71-74 (late) B Body weathers-strip channel
and drip rail seal foam strips (4 rolls
« Reply #4 on: August 13, 2012 - 12:18:02 PM »
That sounds like it.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: August 13, 2012 - 12:32:36 PM »
From my memory it was a pretty thin foam gasket. Hopefully that one is the ticket.
Called Detroit but it seems they are late getting back from the Nats.
B
Offline HP_Cuda
  • Mopar or No Car!
« Reply #6 on: August 13, 2012 - 03:07:17 PM »
Guess I could use Black silicon as well to make the seal.
Running short on time.
Good/bad?
« Reply #7 on: August 13, 2012 - 03:14:17 PM »
Dave at Roseville sells DMT gaskets and so does Mega Parts.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: August 13, 2012 - 03:17:29 PM »
Btw, what are the screws that hold not only the channel in but the drip rail polished pieces which I am guessing mount under the channel piece?
Thanks,
B
« Reply #9 on: August 13, 2012 - 03:52:37 PM »
The drip rail trim is only held on with three or four screws.  The screws are small and have a very flat head on them.  I don't think I have a picture.  The weatherstripping chanel used screws with a round head.  There are teeth under the head as well.  The screws are clear zinc plated.
Offline 4 speed fish
« Reply #10 on: August 13, 2012 - 05:19:25 PM »
Gaskets on Ebay item# 290420595175
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: August 13, 2012 - 07:33:20 PM »
Yep those are it! You guys ROCK!
Thanks!
Bryan
Offline HP_Cuda
  • Mopar or No Car!
« Reply #12 on: August 13, 2012 - 07:35:21 PM »
I found that #8 machine screws with 1/2" depth to them work great for the drip rails and the weatherstrip channel uses the same #8 screws but 5/8" in length with washers. Both are zinc plated.
