Author Topic: AC Heater Control Valve  (Read 1261 times)
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« on: August 13, 2012 - 11:40:46 AM »
I have a generic valve that I was going to mount and noticed that 1 of the 4 tubes is smaller than the rest. Also the cable actuation is the opposite of the dash control (cooler on the dash makes the valve open).
So, I found this on ebay, is it correct?
http://www.ebay.com/itm/OE-Style-Mopar-Cable-Operated-Tempature-Control-Valve-HEATER-VALVE-H1948-or-/230834352429?pt=Motors_Car_Truck_Parts_Accessories&hash=item35beccb12d&vxp=mtr#ht_2867wt_906
Thanks in advance.
Re: AC Heater Control Valve
« Reply #1 on: August 13, 2012 - 11:58:48 AM »
It looks like the ones I have seen but is it identical not positive
Offline peterro
    • The Pistonhead
« Reply #2 on: August 13, 2012 - 12:02:46 PM »
I'm looking more for functionality and I'm not too worried about exact replacement. I'd like it to work correctly with the heater controls on the dash.
Thanks.
Offline 74challenger03
« Reply #3 on: August 14, 2012 - 04:22:03 PM »
1 of the 4 tubes is smaller because it gos to the intake side 1/2 hose
Offline peterro
    • The Pistonhead
« Reply #4 on: August 14, 2012 - 05:09:41 PM »
Hmm, both hoses on my water pump housing are the same size. Same goes for the tubes on the heater core. When you say intake side, which specific connection is that?
« Reply #5 on: August 14, 2012 - 08:09:26 PM »
1st my car is a 318, both lines to the heater core are 5/8 hose. Now going to the engine the 5/8 hose lower line  gos to driver side of water pump. The 1/2 line gos right next to the thermostat on the pass side behind the ac pump.  Hope that helps, i believe my stuff is all original.
Offline swede-cuda
« Reply #6 on: August 21, 2012 - 03:00:24 PM »
          :wave: my -70 bb is the same
