Author Topic: 1970 exhaust manifold help  (Read 6937 times)
Offline ted
  • 74 cuda, 70 challenger r/t
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
Re: 1970 exhaust manifold help
« Reply #16 on: September 01, 2012 - 11:20:11 AM »
What's the part number of the sleeve nut or is there something that the dealer will understand? The last time I went to find parts for my car, the dealer said they couldn't look up anything before 1981 but that if I had the part number they could find it. I need 3 of the nuts and it would be nice to go to the source and avoid e-bay.
Thanks.
Offline GranCuda1970
« Reply #17 on: September 01, 2012 - 12:16:06 PM »
Are you talking about manifold fasteners Peterro?
Offline peterro
    • The Pistonhead
« Reply #18 on: September 01, 2012 - 05:40:07 PM »
« Reply #19 on: September 01, 2012 - 05:58:10 PM »
Yeah that is part of the exhaust manifold fastener kit. you definately want to use the longer Dorman manifold studs to screw into I found that out the hardway those sleeve fasteners won't bite enough on the shorter studs. So I ended up swapping 2 studs last weekend.
did you go with the HP manifolds this kit should have the fasteners you need in it.
http://www.herbsparts.com/proddetail.asp?prod=8065&cat=627
Offline peterro
    • The Pistonhead
« Reply #20 on: September 01, 2012 - 06:57:00 PM »
I believe there are 2 different length sleeve nuts and I need the longer ones (3). Chryco said back on page one that they're still available from Chrysler so I was hoping for the part number. The last show I was hoping to get to is on the 15th and I need the exhaust done so I can get the system installed.
