Author Topic: hood pin install using screws  (Read 2426 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
« on: August 14, 2012 - 11:49:45 AM »
Has anyone installed their hood pins using screws and nuts instead of rivits? If so, what size screw and where can I get some.
Thanks,
Offline 67vertman
  • Member since 9-23-2005
Re: hood pin install using screws
« Reply #1 on: August 14, 2012 - 08:39:00 PM »
I did mine with screws, although I don't know the size.  I can check them out this weekend and let you know.
« Reply #2 on: August 14, 2012 - 09:21:20 PM »
thanks. Did you use nuts or just a screw? I have a fiberglas t/a hood.
« Reply #3 on: August 14, 2012 - 09:51:03 PM »
My kit came with screws for the hood plate. I have no idea what size though?
Offline jimynick
« Reply #4 on: August 14, 2012 - 10:29:39 PM »
1/2" should be lots if it's a sheet metal screw. You don't want the end digging a groove in your melon when you're under the hood.  :22yikes:
« Reply #5 on: August 14, 2012 - 10:42:49 PM »
I'm guessing a machine screw would work with a nut.
Offline 67vertman
« Reply #6 on: August 14, 2012 - 11:49:34 PM »
Just the screws.  But if I had a fiber glass hood I would use screw and nuts.  Even in sheet metal the is not much "meat" for the screws to bite into.
Offline msbaugh
« Reply #7 on: August 15, 2012 - 01:27:10 PM »
Why not just use the rivots? It looks much better
« Reply #8 on: August 15, 2012 - 03:00:24 PM »
The hood was painted black and looks ok, but I want to paint it the correct organisol sometime down the road, so I want to be able to take the hoodpins back off if I need to. I'm guessing the rivots will need to be drilled out??
Offline Barracudadan
« Reply #9 on: August 15, 2012 - 07:08:10 PM »
I used a #6 stainless steel sheetmetal screw 3/4" long there is plenty of room under that part of the hood it wont poke through. Pre- drill it with a 1/8 bit and screw them in by hand so it doesn`t strip out. I myself never liked the pop rivit look and prefer the screws, originality for me is not a concern.
Offline msbaugh
« Reply #10 on: August 16, 2012 - 12:01:56 AM »
Correct all you need to do to remove the rivots is drill the center out. It's not much harder, I say spend the extra 30 minutes getting the tools, it looks better. Sheet metal screw on your hood in my opinion just looks tacky
Offline msbaugh
« Reply #11 on: August 16, 2012 - 12:03:59 AM »
Did rivots come on these hoods originally? Mine is some aftermarket brand it looks great
« Reply #12 on: August 16, 2012 - 03:46:45 PM »
Yes rivits were what Ma Mopar put on originally back in the day. I always thought the rivits looked sort of cheap like somebody did it in their driveway on the weekend. I prefer the look of a phillips head screw better even though it is not correct.
Offline msbaugh
« Reply #13 on: August 16, 2012 - 04:38:27 PM »
I did do it in the driveway on the weekend. haha in fact everything I do on my car is in the driveway on the weekend.  For comparison if you're still deciding
Offline msbaugh
« Reply #14 on: August 16, 2012 - 04:40:12 PM »
The stupid things have been scratched up from me having to force the pins in! Did I install it wrong? Instead of the square look of the rivots while looking head on like the picture above mine is oreiented differently, I must've had a few drinks that day  :roflsmiley:
« Last Edit: August 16, 2012 - 04:44:18 PM by msbaugh »
