Author Topic: conversion std dash to rally in 70 chally vert. what to do and what parts?  (Read 916 times)
Offline 71cudafish
 any   help on parts or tech side of job would be great THANKS  Mark :thumbsup:
Offline 4 speed fish
70-71 Rallye gauges and bezels.Rallye heater bezel.Rallye light bar.Reset Knobs.Correct Rallye Wiring harness.I would remove entire dash from car and assemble on a work bench.
You don't need a different harness if you make a couple of mods to the existing one. You'll need to run a wire from the "-" side of the coil to the tach for it's signal. You'll need to run a wire from a switched power source for the tach power. Run a wire from a constant power source for the clock. Then last but not least, you'll need a different oil pressure sending unit for the oil pressure gauge.
Offline ragtopdodge
Super easy.
Ya, keep the original harness.  Bill and Rose Evans do make a little tach wire harness add-on.
Change the sending unit (oil) from idiot light to gauge
Just a few screws and the old stuff comes out.  Just got to drop the column some.
70-71 gauges run usually between $350 (rebuildable cores) to $2k (fully rebuilt).
Not hard at all!
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
I also might add, the heater panel and 70-71 gauges make this a costly swap. The Rally gauge light bar can bring $200 on E-Bay.    :money:
