Author Topic: RPM SB intake  (Read 593 times)
Offline EMCD
RPM SB intake
« on: August 15, 2012 - 10:11:11 PM »
Does this intake have the cross overs that help with cold starts? If so, how do you block them?
Re: RPM SB intake
« Reply #1 on: August 15, 2012 - 11:29:32 PM »
The RPM does , the RPM air gap does not , so if you have not bought it yet buy the air gap .
 If already have the intake you either need a thin piece of stainless steel or cut a section out of the old intake gasket if it is a steel lined one & silicone a patch into the new gasket e
Offline msbaugh
Re: RPM SB intake
« Reply #2 on: August 16, 2012 - 01:01:50 AM »
I bought the regular rpm Manifold right before the air gaps came out! I was pissed that they didn't get it out a couple months sooner!  :banghead:
Some metal valley treys for the big blocks have block off plates for the cross over. Mine hasn't burned up a hole through it yet so I think it's safe to say that as long as its a good quality metal piece it'll do ok for blocking it off.
Re: RPM SB intake
« Reply #3 on: August 16, 2012 - 08:34:19 AM »
Sorry if yours is a big block , the 1214 for B engines & the 1215 for RB will work
