Author Topic: Does anyone know how to remove the rear Gill trim on my 1968 Barracuda V8?  (Read 510 times)
Offline Aracer
It is stuck into the end of the skinny rocker trim, And I can't remember if I tapped it out to the rear or I lifted the trim. I did paint this 28 yrs ago. Now the slicks need the extra room. The Gill is cast and the screws are out and it's hanging on. I will stay logged in until I get help, thank you.
      I guess I'm the only one who has a 1968 Cuda with the cast Aluminum Alloy Chrome rear Gills? They must be worth $500 for the pair, if no one has them.
TA DA!! It taps frontward with a door wood shim on the edge, so as not to deform the edge. The bastard did not move last nite, but just now it was 1/8" forward, so I knew to tap lightly until the BLIND screw was revealed. Never put in blind screws again! I think now, that WD-40 might have helped or liquid soap. F-en A! that was annoying and as always, glad to ***** about somthin. Pictures in an hour, really!
« Last Edit: August 18, 2012 - 08:13:16 PM by Aracer »
