Author Topic: exhaust setup for 74 cuda 318 advice?  (Read 1980 times)
Offline Shane_OBrien14
« on: August 19, 2012 - 06:40:44 PM »
wondering what setups other guys have in the car? what mufflers and pipe size?
Re: exhaust setup for 74 cuda 318 advice?
« Reply #1 on: August 19, 2012 - 07:14:28 PM »
Accurate Exhaust has both single and dual exhaust systems for the 318.  You need to give them the part #'s of your exhaust manifolds when ordering.  If you have headers on the car, you'll need to look into another company.
My Accurate system is 2" off the manifolds and expands to 2 1/4" the rest of the way back.
« Reply #2 on: August 20, 2012 - 12:26:14 AM »
I would use dual , 2" should be lots on a 318 , mufflers can be anything depending what sound you like .
Offline Road_Runner
« Reply #3 on: August 20, 2012 - 08:45:06 AM »
I have a muffler shop 2 1/4" dual exhaust with what looks like flowmaster welded aluminum mufflers on my 73 318 Barracuda.  Sounds great for a basically stock motor.  If I build up the 318 or swap in a 340 I 'may' put headers on it, but I really like the mellower sound and stock look on this car.  I have heard a lot of good things about accurate exhaust if you're keeping yours stock appearing, otherwise I'd also check out systems from TTI, magnaflow, etc.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
« Reply #4 on: August 20, 2012 - 07:43:25 PM »
thanks i just fired her up for the first time after i installed my headers today, dripping some oil from the oil filter adapter, maybe its just the gaskets inside?
Offline cudazappa
« Reply #5 on: August 20, 2012 - 08:32:25 PM »
Right now I have Doug's Headers and Summit 2.5" exhaust.  Sounds good, but need more engine  :burnout:
2015 Dart GT - Daily Driver
Offline dougs bs23
« Reply #6 on: August 20, 2012 - 10:31:49 PM »
On my 340 I have Dougs headers and linked them to a 2-1/2" Xpipe Pypes stainless with their streetpro muffs. Took a little tweaking to get the tails centered on the tips. Looks good and sounds pretty mean.
