I would go for, ede RPM-airgap, TTi headers, RHS heads, hydraulic roller cam in the low 260-275 duration, .550 lift, if you want more lift go with 1.6 roller rockers. Keeping the duration low will make it more drivable, increase fuel economy, etc. However, this combo would make more like 400hp, if you are only looking to a have horse per cube, rebuild it with headers, 3 angle valve job, and use the big CFM thermoquad. That would put it in the 330-350 hp range easily.
Sent from my DROID RAZR using Tapatalk 2
