Author Topic: Steering box play  (Read 9749 times)
Offline Glennster
Steering box play
« on: August 24, 2012 - 06:04:19 AM »
 Can some of the slop in my steering box be taken out with an adjustment? I see a set screw with a nut on top of my steering box and I have about an 1/8 turn of play in my steering wheel.
 What does that adjustment do?
Offline 440STRKR
Steering box play
« Reply #1 on: August 24, 2012 - 07:45:06 AM »
If you adjust the screw by turning it clockwise further into the box it will tighten it up, but also bind and full lock and wear the worm gear in your box faster. Mopar power steering is the worst... You can send your box to a company called firmfeel and they will rebuild it to be as tight as you prefer (stage 1, 2, or 3) 3 being what most people consider "tight".
Offline 440STRKR
Steering box play
« Reply #2 on: August 24, 2012 - 07:45:41 AM »
I meant bind at full lock
Re: Steering box play
« Reply #3 on: August 24, 2012 - 10:13:36 AM »
I do this all the time , make sure the steering box is centered , this is where the two gears have the least play , if you release the locknut & tighten the screw it will remove play , go too far & it will become hard to turn over center or jam at center
« Reply #4 on: August 24, 2012 - 10:39:09 AM »
I believe there is a specific adjustment procedure for that.  You tighten it so it is snug...and then back it off so many turns.  I don't know what the exact specs are for it though.
Offline JoltinJoe
  • BALZ TO THE WALZ MAN
« Reply #5 on: August 24, 2012 - 10:37:19 PM »
 :popcorn:
HIS: '68 GMC 3/4 ton pick-up truck, '73 Barracuda, '87 Firebird, '01 Jeep Cherokee and finally a '70 Barracuda Convertible!
HERS: 1980 Toyota Starlet, 1995 SAAB 9-5 and then '01 SAAB 9-3 and currently '08 Saab 9-3 convertible!
NEXT IS MINE: purple 2010 Dodge Challenger!!!
Offline Glennster
« Reply #6 on: August 31, 2012 - 07:37:45 AM »
Should I try turning the bolt a 1/4 turn at a time and go for test rides to check it? Or should I turn it until I feel resistance?
Offline 73restomod
« Reply #7 on: August 31, 2012 - 10:57:23 AM »
Best way to do this that I have found is to lift the wheels up, start the car, tighten the adjusting screw with 1 hand while turning the steering shaft with my other hand. Stop tightening it when you see the wheels move at even the slightest movement of the steering shaft, and lock it down. If the box had much more than 50 k on it, you might as well rebuild it first.
Sent from my DROID RAZR using Tapatalk 2
« Reply #8 on: August 31, 2012 - 10:13:55 PM »
I turn it in until I feel resistance , it will certainly be better , just make sure it goes over center without resistance
« Last Edit: September 01, 2012 - 01:09:02 AM by Chryco Psycho »
Offline spamtank
« Reply #9 on: August 31, 2012 - 11:20:25 PM »
What's an acceptable amount of backlash or slop?   :dunno: :clueless:  I've got ~1/32 of a turn.  But it's not zero like my civic or mini cooper.
I'm guessing that's pretty good for a 42 year old car.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
« Reply #10 on: September 01, 2012 - 01:11:21 AM »
there really should be no slop / wheel movement without the car responding , I bet the adjuster screw will go a least a full turn
