Author Topic: What to check on Stealth heads?  (Read 3109 times)
Offline Perry
Re: What to check on Stealth heads?
« Reply #15 on: September 19, 2012 - 12:43:16 AM »
I heard back from my shop today and they charged me $275 for the work I described above. That's not too bad. I am starting to think I should have had the springs replaced but these will have to do for now. This is a mild street engine so I don't plan on going all out on the cam.
Perry
« Reply #16 on: September 19, 2012 - 08:32:31 AM »
Don bought some cnc'd stealth heads for his 493 I built for him. They are making good power for a low cost street engine.  You can squeeze  700 hp out of them with a good combo
Were they the 'super stealths'? I see they only come bare.
Offline PlumCraZRT
« Reply #17 on: September 19, 2012 - 11:18:01 AM »
Perry
If it were me, I would seriously consider replacing the springs when you decide on a cam.  Spring technology has come a long ways (as far as reduced fatigue is concerned) and it would be a bad day when a failed spring scraps your engine.  Look into a Lunati or custom cam for your combo.
mmmmm.... Mopar.... *drool*
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #18 on: September 19, 2012 - 12:50:42 PM »
Cam Motion does a super job on custom grinding cams. I have a Cam Motion cam in my big block.  :2thumbs:
        Matt B.
Matt
Offline Perry
« Reply #19 on: September 19, 2012 - 06:05:17 PM »
But these springs are new. I understand that often the cam dictates which springs are needed but are the stock 440 source springs no good at all? Just placeholders to be tossed away when somebody selects their cam?
I am looking at a Lunati cam as they come pretty recommended on this site.
Perry
Offline HP_Cuda
  • Mopar or No Car!
« Reply #20 on: September 20, 2012 - 12:18:17 PM »
The 440source page states the springs are rated up to maximum .510" lift.
So if you have a crazy cam then you need to swap them out.
B
Offline PlumCraZRT
« Reply #21 on: September 21, 2012 - 03:15:57 AM »
B
As CP can attest to, .510" lift should NOT be considered "crazy" lift.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #22 on: September 21, 2012 - 03:21:46 AM »
Crazy is a relative term but if you want to compare it to a stock mopar cam then it definately falls below that.
 :violin:
Offline Perry
« Reply #23 on: September 21, 2012 - 09:12:12 PM »
Looking at the website it shows that the maximum lift is .600 for the springs. The .510 limitation is for the 7 degree locks that are included. I upgraded to the 10 degree locks which are good up through .600. At least that is my understanding based on their website and various posts I have read.
Perry
