Author Topic: Car stalls after 30-40 minutes  (Read 4173 times)
Offline BP23G0B
Re: Car stalls after 30-40 minutes
« Reply #15 on: September 09, 2012 - 10:11:25 AM »
probably the distributor. It's the only thing not changed when the problem came back,
Possibly.  I did hook up an elecronic ignition tester (from DP I think?) and it failed at the ballast (aux side).  It did give an ECU failure after that, but if there is something going on upstream I don't think I can call the ECU out on it.  I'm thinking it's the eHarness or dizzy.
'70 Barracuda Gran Coupe
'14 Ram 1500 Express Black Edition
« Reply #16 on: September 09, 2012 - 01:22:26 PM »
the pick up in the dist can shut down with heat & over 2-30 mins
