Author Topic: Going back to 00,000  (Read 4906 times)
« on: August 26, 2012 - 10:18:08 PM »
My Rallye Odometer is at around 97,000.
I thought about taking the speedo cable, hooking it up, and spinning it till it hits 00,000.
Hoping this doesn't hurt anything.
I also recall many moons ago; that someone said there's a ink that tints the first number once it turns over past 100,000.
I would like to avoid that if that's true. Can anyone verify this?
If anybody has info on going back to 00,000, I would like to hear how you did it and results.
Thanks
« Last Edit: August 26, 2012 - 10:20:09 PM by Topcat »
Re: Going back to 00,000
« Reply #1 on: August 26, 2012 - 10:54:56 PM »
Easily done & often done with entire rebuilds
 I just pop out the odometer drum & spin the section needed to return to zero & pop it back in .
 Yes there is an ink pad that sits on the highest # from the factory & discolors the high # wheel
Offline GranCuda1970
« Reply #2 on: August 26, 2012 - 11:13:21 PM »
Yeah I got 70 something thou on my odometer and would like to take her to zero with the new EVERYTHING.
« Reply #3 on: August 26, 2012 - 11:32:43 PM »
Would be a great "how to" archives.
With pictures.
« Reply #4 on: August 27, 2012 - 11:16:45 AM »
Aren't your odometer numbers discolored?  Mine weren't that bad but they were still yellowed.  I had mine redone and told the rebuilder specifically NOT to zero out the odometer.  They are only original once.
« Reply #5 on: August 27, 2012 - 12:46:04 PM »
Probably illegal to do it as well , Where is Barry / Alaskan , probably sending the cops after me already ?
« Reply #6 on: August 27, 2012 - 12:59:43 PM »
Yeah, I think the beginning of the movie Used Cars was the dealership rolling back odometers.
« Reply #7 on: August 27, 2012 - 01:36:51 PM »
it is stupid simple , unbolt the speedo for the housing , the drum with the #s is clipped in on both sides with retainer , remove the drum , this will allow you to rotate each drum next to the one you want to change so it takes a couple of minutes to reset to zero & clip it back into place in the speedo . the first [highest drum will be discolored , if you have to sell the car the the milage can be legally registered as unknown being as the car is 40 years old , or you can document the original milage & date & add the new milage from the reset . . I had an old 82 Slant 6 truck , used when I bought it & I drove it for 5-6 years & put 150k miles on it , or 200k kms , who know haow many times the odometer has been around 300k 400k , 500 k  :dunno:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #8 on: August 27, 2012 - 03:13:53 PM »
Chryco does it again!
I must have lost a clip on one side of my drum hence it would hang down. Problem now identified, now I just have to get a new clip as I've already reset my odometer. Thought something wasn't right.
I promise I won't send the odometer police to Panama!!!
 :roflsmiley:
Bryan
« Reply #9 on: August 27, 2012 - 06:33:11 PM »
 :roflsmiley:
Bryan
 :smilielol:
« Reply #10 on: August 27, 2012 - 07:18:08 PM »
well oddly there is no postal system in panama so my street address here is "road" in Coronado
Offline HP_Cuda
  • Mopar or No Car!
« Reply #11 on: August 27, 2012 - 08:25:42 PM »
Watch it those guys are very industrious! El policia odometer!
By the way, know where I can find clips?
« Last Edit: August 27, 2012 - 09:31:32 PM by HP_Cuda »
« Reply #12 on: August 27, 2012 - 09:05:51 PM »
I have only seen them on a speedo , you may have to swipe one from a 4 dr valiant
Offline HP_Cuda
  • Mopar or No Car!
« Reply #13 on: August 27, 2012 - 09:31:56 PM »
Hmmm okay guess I'd better start looking or rob one off another speedo.
Offline cuda346pk
« Reply #14 on: August 28, 2012 - 01:35:11 AM »
:iagree: I had mine apart during a dash rebuild and accidentally dropped my drum out. Got it back in fine but oddly after a couple hundred miles the left, highest, number is halfway  between 2 and 3. Figure I will fix it next time around.
David - In Georgia
1972 'Cuda In-Violet 340 6 Pack 4 Speed 3.91 Sure Grip - Finally, after 27 years of waiting and dreaming it is real. Now the fun begins!
